Need a schematic for this powered subwoofer. No response from Velodyne, shot in the dark hoping someone else has worked on this. Found a CT120 but the drivers are completely different. Need the preamp board as well.
Velodyne CT100
I do not have that particular schematic. But>>>>
Honestly, the amp does not look that complicated.
The preamp has 1 LM339 and 2 LM384 opamps.
The power output is a STK4040II.
The power supply is a linear design.
STK4040II.pdf
According to a gent over at AudioKarma, there are two versions of this amp.Last edited by Jazz P Bass; 04-01-2018, 01:08 AM.
I haven't looked at the age but the hot spots on the board tells me it got some use. Sorry I meant to say ba4558 not ba4886..not sure where that came from. I replaced the outputs as they were shorted but for some reason the preamp board lights up the dim bulb when connected. I still have some power amp board issues as it will not produce sound with a signal injected. Voltages all look right but without a schematic I am shooting in the dark to some degree.
Originally posted by tdlunsfo View PostI replaced the outputs as they were shorted but for some reason the preamp board lights up the dim bulb when connected.
The preamp board can´t even be connected by itself to mains, so look at it and describe what IS connected.
Meaning:
* is power transformer connected?
* is power supply (basically diodes and capacitors) connected?
* is power amp connected?
any of these has muscle enough to light a series bulb, wimpy preamp does not.
I still have some power amp board issues as it will not produce sound with a signal injected.Juan Manuel Fahey
Here are some pics to get a reference. I can connect the power amp/ power supply board without the preamp board and it will fire up and the relay clicks. When the preamp board is connected the dim bulb lights. My first goal was to get the power amp to pass a signal then tackle the preamp board. I am at a point where I need a schematic to help me trace and develop troubleshooting tests.
If it uses a upc1298v then you have half your problems solved, I bet they use the straight datasheet example, what else?
Maybe with very minor variations or tweakings, compare that schematic to what you have in your own, should be real close.Juan Manuel Fahey
Ok, even if tweaked, upc1298 + IN is still Pin 4 .
It will some 10k to 100k resistor to ground, and most probably a coupling capacitor.
At the same time, 1 of the input ribbon connector 7 pins is the Audio Input.
So there must be some path leading from connector to Power Driver
It might not be straight, I see a JRC4560 in the middle, it *might* be an active lowpass to feed the subwoofer ppower amp.
If dead, no signal will reach power stage.
So check it has proper +/-15V on pins 8 and 4 respectively, that you do not have more than a few mV DC on outputs, pins 1 and 7, confirm that one track leads to one of its inputs from input connector (with maybe some capacitors and resistors in the path) , that another track (same thing) goes from one of its outputs to power amp driver, etc.
You see there is a couple things to test even without the proper schematic.
Try injecting some audio (even fingertip buzz) straight to driver IC and listen at "a" speaker, any spare speaker you have around.
If no sound, the Power Amp is NOT repaired yet (IF relay clicks, of course)
If you hear something, move backwards towards input until you find a dead zone.
Please report results.
FWIW I live in Argentina, very little information and no access to original parts ... yet stuff gets repairedJuan Manuel Fahey
