Results 1 to 3 of 3
Thread: Kastam echo 8 track tapes
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    These use a modified 8-track cartridge with 200ft of tape and wider cutouts to accommodate the additional head. Does anyone know if they have a foil splice and will they run OK on a regular length cartridge? I'm thinking that 200ft is about 10 minutes at a normal playback speed of 3.75" per second, which is quite a short run. The one I have is still on its original cartridge and there isn't much oxide left, plus the roller is hard and the pads soft.
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,671
    Received: 44/0
    Can you just instal a "better" roller and pads scavenged from another 8 track tape? In general its also just 1/4" normal bias reel to reel tape in one. You can reload the cartridge by cutting the tape, splicing new tape to it, pull the other end until the new tape comes through, the cut and splice the new ends together. Btw... late production 8 tracks had hard plastic rollers. You might need to rough up the capstan with a bit of fine Emory cloth. We used to use a matchbook cover.
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    I'll give that method of reloading a try. I had it in my mind that the tape was specially coated on the back for 8-tracks so it would pull from the centre of the spool. I have some regular 1/4" tape so will see how it goes.
  1. 8-Track Tape Echo with no echo
    By ggjgjhkihkjhiuyiy8788 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2017, 09:13 PM
  2. What tapes for an Echoplex
    By bpier in forum Guitar Effects
    Last Post: 05-11-2012, 10:34 PM
  3. Multivox Tape Echo (just like Roland 201) has low output distorted echo
    By eurekaiv in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-05-2009, 08:08 PM
  4. tapes for Space Echo
    By rossl in forum Guitar Effects
    Last Post: 02-18-2009, 07:59 PM
  5. Paper (and other) tapes in Europe
    By Yves in forum Pickup Makers
    Last Post: 04-22-2008, 07:31 PM
