Results 1 to 18 of 18
Thread: Another Marshall valvestate 8004 blowing up Tda1514's
    May 2010
    Des Moines
    218
    I just need a bit of help with a Zener question. As I wait for parts, I can't get the two rails to match. One side of the amp ( left/chan A) works. But the other is whacked. I did replace TR2 but still have too much of a voltage difference on either side of c4 and c6. They should be similar right? Well one is negative. But I see 27v on A side and -34 on B side. Is ZD2 most likely the culprit of not dropping enough?
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    It's a good idea to post a schematic or schematic link when you start a thread so we know what you're talking about.
    http://www.thetubestore.com/lib/thet...-Schematic.pdf
    May 2010
    Des Moines
    218
    Oops. I thought I did 😏
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    Do you measure any AC on the low rail? You might have a bad filter cap. Do you have the shorted TDA or TDA's removed? If one is defective, it might load down a rail. If you suspect a zener is bad, measure the voltage drop across it. It should be around 27VDC. Are either TR1 or TR2 shorted?
    Edit: Also check that C12 &13 are soldered in well- no cold/cracked joints.
    May 2010
    Des Moines
    218
    Yes the TDA is pulled out.My meter won't read 2200 uf. Maybe c12 is bad? I will just replace him. The Zener must be bad , I will double check the voltage drop when I get back to the bench tomorrow. I do remember seeing zero volts on one side of the diode?
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    Check the AC voltage across the cap. If it's not doing it's job, there will be ripple/AC there. If the supply is clean, no need to replace it. One side of each zener is ground, so yes there will be zero volts on one side of each. It's the other side you need to measure. If there's 27 volts there, no need to change that either. There's no need to shotgun it. Troubleshoot your way through the supply and figure out what's wrong with it.
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    I am confused as to the question of what is wrong.
    The OP stated that "One side of the amp ( left/chan A) works. But the other is whacked."
    The power supply is common to both TDA1514's, is it not?
    I would also like to know where the OP is going to find a non- bogus TDA1514.
    May 2010
    Des Moines
    218
    I have blown up 2 TdA's from China. I now ordered one from a USA supplier that is a confirmed Phillips. We shall see.
    The weird thing I am seeing is the volt drop across R2 on channel A is about 8 volts and the drop on R3 is only 2 volts? I replaced r3 and still same 2 volt drop....?
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    Agree.
    If +rail is +27V *for both* amps, then negative rail (if regulator is shorted or Zener is open) , can be -34V, for both again.
    I see this circuit as a (factory) kludge.
    Clearly they have a ton of , say, 24+24VAC transformers , most probably ordered for some other more popular design (or surplus from a model which did NOT sell well) but TDA1514 insists on no more than 26V DC rails, so they added a couple BDV64/65 (which might also be overstock) to down regulate 34V rails to 26V ones.
    99.998% of power amps do NOT use regulated supplies
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    Quote Originally Posted by 888guitars View Post
    This makes sense if the zener is defective or has bad connections.
    Also, R2 and R3 are not on "channel A", but should be common to both channels, as was mentioned in post #7.
    So there appear to be 2 separate problems, one is the zener problem, with which the amps may still work ok (as ch.A shows) for awhile.
    The second problem is the bad amp.
    Fix the zener problem first. It could be that the newer amp chips can't handle the excess V- supply, where the old one in ch.A seems to be ok with it for now. But the excess V- could end up blowing the ch.A amp chip as well.
    May 2010
    Des Moines
    218
    Wait? I see it as R2 is the positive rail and r3 the negative. They should be similar except for the pnp vs npn. So when I look at either side of c4 and c6 they should be somewhat mirrored. Right? In that case the same voltage drop across R2 should be the same same as for r3? But they aren't even after replacing them. I replaced the Zener with a half watt 27v I had as I'm waiting for a bigger one, but nothing changed?
    Everything is good after the bridge and after the filter caps. It gets goofed up on the " input right" side at the BDV64 and Zener which both have been replaced with no change in voltage?
  12. #12
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    The ultimate aim of the two "pass" voltage regulator circuits is to regulate the voltage down to + - 27 Vdc.
    ON the Emitter Lead of the transistors.
    I have yet to see a measurement at C4 & C6.
  13. #13
    May 2010
    Des Moines
    218
    C4 27v and c6 is -34
  14. #14
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Aaah. Thankyou.
    TR2 is not doing anything at all.
    It is either the incorrect part or maybe the zener is in backwards.
  15. #15
    May 2010
    Des Moines
    218
    Good thing I got 2 from mouser. I’ll pull it and check the zener again.
  16. #16
    Oct 2007
    10,291
    Received: 354/5
    Given: 356/5
    Measure voltage on both ends (anode and cathode) of ZD2.
    If track/solder is open between its anode and TR2 base or between its cathode and ground, it won´t do its job.
    Like Enzo says, shotgunning parts is not enough, only half problems come from bad parts, other half comes from poor connections (cold solder, cracked tracks, dirty contacts, frayed wires, etc.)
    Time and time again we read distressed posts like"I´m going mad, replaced *every single component* in the board and still the damn amp does not work!!!"
    Personally I always insist on taking voltage readings all over the place and when finding a weird one, trying to find what caused it.
    You read bad rails (fine) and indirectly read weird TR2 base voltage (2 V below raw supply voltage instead of 8V below like the other one) but failed to act on that useful piece of data.
    I bet TR1 base is 27V away from ground, while TR2 base is some 32V away ... a clear indication that the 27V Zener is not doing its job.
    Why? ... go find it
  17. #17
    May 2010
    Des Moines
    218
    Yes master Jedi sir. 🤟
  18. #18
    May 2010
    Des Moines
    218
    After going through 5 bad TDA’s, I finally got one that seems legit. At
    Least they gave me my money back but how frustrating 😫
  1. Marshall AVT50 Valvestate 200 Combo blowing main fuse
    By music.man in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-09-2016, 11:31 PM
  2. Another MARSHALL Valvestate 2000 AVT150 Blowing fuses......
    By blearyeyes in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2015, 06:33 AM
  3. Marshall Valvestate 8004 - Blowing TDA1514A's
    By NickH in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-21-2015, 06:56 PM
  4. Marshall Valvestate VS100R Transistors Blowing
    By neilm in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2009, 12:00 AM
  5. Marshall valvestate 8100 blowing fuses
    By goldtop5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-17-2007, 01:24 AM
