Results 1 to 4 of 4
Thread: JBL EON 510 Input Module Schematic needed
    New Member
    Apr 2018
    2
    Hi everyone,
    I got a defect JBL EON 510 speaker ( no sound, but all LED are ok ). It contains 2 modules: input module and amplifier module. I found the schematic for the amplifier and this seems ok.
    Now it would be very helpful to have the schematic for the input module ( it has several 4580 op-amp ICs ).
    Dec 2008
    Wernersville, PA
    12,351
    Received: 105/0
    Given: 31/0
    This is all that I have.
    Eon 515 mix: E515 IO Mixer.zip
    New Member
    Sep 2016
    1
    just a suggestion, but check if the EQ switch is good.
    If the switch is broken inside, the input led will light up that there is signal but no sound will come out.
    New Member
    Apr 2018
    2
    Fixed it!
    Shandryderrick you were right, it was the EQ - switch. Bridged the switch in position "FLAT" from pin 1 to pin 3, as I don't need the EQ that often.
    Jazz P Bass & Shandryderrick, thanks for the excellent support.
  1. Wanted: JBL EON 510 schematic
    By telecaster in forum Schematic Requests
    Last Post: 09-30-2016, 03:38 AM
  2. JBL eon 510 broken OUTPUT (mix/loop) and EQ
    By dotbox in forum Other Amps
    Last Post: 01-12-2016, 11:46 PM
  3. JBL EON dissassembly?
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-08-2013, 05:47 PM
  4. Looking for a schematic for a JBL Eon 15P-1
    By Drewline in forum Schematic Requests
    Last Post: 06-06-2013, 06:24 PM
  5. JBL Eon 515 schematic
    By diydidi in forum Schematic Requests
    Last Post: 02-10-2012, 01:09 AM
