Fender Frontman 212R
  • Fender Frontman 212R
    Hi
    sorry for my english, i'm from Russia
    i have problem with my 212R
    My amp start crackling after about 1 hour of using, also R144 and R145 are very hot
    i replaced all polar capacitors and potetiometres
    Originally posted by kebaborg View Post
    Hi
    Welcome
    they DO work hot, thatīs why they fit 5W resistors there.
    You should not have done that.
    Nothing suggested they are bad; at most you should have *cleaned* them first with some potentiometer/switch/contact cleaner spray.
    You must first find the problem, then try to solve it.
    Ok, then first try to find which area can crackling come from.
    * does any control have any effect on crackle?
    * does it happen on both channels?
    * if you plug a spare guitar cable in the Loop In/Return (keep the other end unplugged but touching nothing) , does crackling stop? It might hum now but that is not to worry at this moment.
    * if you hit amplifier top hard with your closed fist, does crackle stop/increase/"crackle" ... this might show some loose part or connection inside.
    Now itīs already done but every part you replaced with no reason *increases* the possibilities of poor new contacts, without solving the original one .
    Ok, do those tests and report results.
      no
      yes
      no
      no
        If it starts after warmup, I'd try a can of freeze spray and see if you can narrow it down with that.
