Results 1 to 14 of 14
Thread: Mesa Boogie .50 Caliber + Combo Reverb problem
    Feb 2008
    112
    I recently acquired a Mesa .50 Cal. + Combo. The amp come without a reverb tank.
    Ordered correct new tank with new cables... no reverb .
    Change out AT7 in V4 ... no reverb. I can tap tank and hear faint spring noise, also hum from
    reverb out using the pot.
    Using the schematic here are my voltages V4-1 97v
    V4-3 .88v
    V4-6 214v
    V4-8 1.7v
    Re-touched up all solder joints
    Other than reverb the amp works great.
    Thanks for the help
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Which tank did you get and/or what are input and output impedances? Are you sure you don't have input and output switched?
    Feb 2008
    112
    MOD 8AB2A1B In 1.3 ohms Out 224 ohms . Yes I switch the in and out cables , thanks
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Not to pick nits, but impedance specs for that tank are input 10 ohms and output 2,575 ohms. At any rate, it should be the right tank.
    Feb 2008
    112
    sorry misread my meter , the tank does spec out correct ... Can I check the transformer ?
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Your meter will show you resistance. Impedance is a different animal. I doubt you have and open transformer. Most common failure is open primary. If that happens, you wouldn't have voltage on the plate of V4B. You can certainly check that the secondary isn't open. Do you have a scope? If so, start tracing signal.
    Feb 2008
    112
    Should I be showing resistance between the reverb in and out at the amp ? thanks
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    I'm not sure what you're asking. If you mean positive connection input to positive connection output, you'd get no resistance since one connection only goes to a tube grid.
    Feb 2008
    112
    Yes that is what I was asking , just trying to determine if the reverb trans is ok ..thanks
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    You said you could only hear the springs faintly. With reverb and volumes up, a good thump to the tank should give you a loud crashing sound.
    If you can't get that, then the problem is in the recovery circuit, not the drive (transformer) side.
  12. #12
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    Also, a very simple check for the reverb transformer is to take the cable that goes to the 'in' of the tank, and connect it to an 8 ohm speaker. If you get sound, the reverb driver transformer is good.
  13. #13
    Feb 2008
    112
    Not getting any sound ? thanks
  14. #14
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Did you check the transformer secondary for continuity- from the reverb send of the amp to ground?
  1. Mesa Boogie 50 Caliber + head noise problem
    By beatnik in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-01-2016, 01:14 PM
  2. Replies: 13
    Last Post: 11-06-2015, 05:39 AM
  3. Mesa Boogie .50 Caliber Plus Schematic
    By Chevy in forum Schematic Requests
    Last Post: 10-10-2013, 01:10 AM
  4. Mesa Boogie Caliber 50+; effects loop problems
    By Bernardduur in forum Mods & Tweaks
    Last Post: 12-27-2012, 05:40 PM
  5. Mesa Boogie 50 Caliber + red plating
    By rkohansk in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-14-2010, 12:40 AM
