Results 1 to 4 of 4
Thread: Rhodes Satellite amp confusion
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,688
    Received: 67/0
    Given: 10/0
    1970s Fender Rhodes 2x12 powered cabinet that doesn't pass signal, only some hum. I have both rails +/-43v. outputs test good. As I trace my signal, I find that if I apply it to the neg side of the 5uF/50v cap after the input trim pot, I get nothing, ut if I apply it to the positive side of that same cap it comes out loud and clear. So I figure bad cap, right? Popped in a new one and same issue. Then I clip in different values and here is where it gets weird. FOR A TIME, the original cap WORKED SOMEWHAT, but any new ones, not at all. Old cap tests OK. Now, after much noodling around no cap works. HOWEVER, I can see signal getting to Q1 base and at it's emitter to a little lesser extent.
    So, why does essentially shorting this cap make it work? Was the old cap intermittantly shorting or leaky to the extent it acted like a piece of wire? So Here I am at clip in a cap of similar value, nothing. Short the clip leads together and, loud.
    Q1 - 3 test good, but here is something that has me wondering, I have 32v on the base of Q1, is that turning it off? Here are what I see for voltages in the section:
    Q1 b = 32.6v
    c = 33.8
    e = 32.5
    Q2 b = 25.3
    c = 26.8
    e = 32.5
    Q3 b= 26.6
    c = 27.0
    e = 26.0
    Sure wish they had bothered to include voltages on this print:
    http://www.fenderrhodes.com/org/ch11/fig11-12.jpg
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Neither Q1 or Q2 is biased properly. Is Q1 shorted B-E? I'm assuming that in your post, Q2 base is supposed to be positive (misprint)? Either way, an NPN transistor should have the base approximately .6 V more positive than the emitter. So, Q2 isn't right either. Is the B-E junction open? Use diode check function on your meter and check the transistors.
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    Agree with above, also, I think when you originally injected your signal at the + end of C13, you were somehow biasing Q1 with your test gear.
    Jan 2013
    Cape Coral, FL
    1,688
    Received: 67/0
    Given: 10/0
    You are correct sir! I doubled checked those two NPNs and Q1 was indeed shorted B-E. I checked it before on a B&K transistor tester so I think I may have used the wrong setting. Anyway, it is passing signal now. Now I have to address the caps situation to relieve it of it's hum
    Thank you!
  1. 4 pin rhodes power amp gets hot on one side
    By Skiroy in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-22-2011, 06:08 AM
  2. Rhodes Suitcase Dual 50W amp
    By melvin in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-18-2009, 11:33 AM
  3. Mesa Simul Satellite
    By Zouto in forum Schematic Requests
    Last Post: 05-06-2009, 09:36 AM
  4. Tube Amp Design Confusion
    By apehead in forum Theory & Design
    Last Post: 04-03-2009, 08:56 PM
  5. moog satellite schematic
    By billybillybilly in forum Schematic Requests
    Last Post: 02-24-2009, 05:54 AM
