Switchcraft Stereo panel jack question.
  • Switchcraft Stereo panel jack question.
    Hey All,
    I'm in the middle of a rewire on a Hamer and came up with a question.
    I have one of these:
    http://www.wdmusic.com/switchcraft_p...29648_prd1.htm
    There's 2 lugs at the hot end 1 is shorter than the other- does it matter which lug I use for signal and which gets used for switching ? I'm using the jack to turn on and off an onboard preamp battery.
    Thanks, Dan
    www.danielzink.com
    Yes it matters. The short lug is the tip, the next one is the ring. The signal goes to the tip of the plug.
    Double check by plugging in a mono cable and use your meter to see which lug has continuity with the tip of the cable. The other lug will be shorted to ground.
      Thanks Again !
      Dan
      www.danielzink.com
