So I decided to drop the B+ on this '66 Ampeg Gemini VI I'm working on to something the 7591's will live with. I got a 50 Watt chassis mount 47 Volt zener to put in the center tap. After installation, the voltage is down about 45 volts as expected. The problem is now I get a 120 Hz hum. I added a cap across the zener starting with .1uf going up to 22uf. That didn't do much at all. I tried another zener I had rated at 26 volts and that made no difference. I tried grounding the zener to places other than the chassis like the can cap ground, power tube cathodes and even the input jack. That didn't change anything. The pilot light is connected to the center tap, so I disconnected both wires thinking that might have something to do with it. Now for the odd part. I can get rid of the hum if I remove the phase inverter (7199) or disconnect the pentode from the triode. I did try another 7199 and a 6U8 (after rewiring the socket). If I bypass the zener, the hum goes away. Any ideas or other things I can test? Thanks!
Hum After Zener Diode Voltage Reduction
Put a big-ass resistor right after the diodes. Are your filament voltages also higher than they should be? Maybe a bucking transformer is in order. How are you figuring the voltages are too high? There is nothing shown on the schematic. Found another schematic but can't read it too well, electrotanya website. You may have to register to get it, 450 b+?Last edited by mozz; 05-09-2018, 11:55 PM.
The filaments are 6.6 vac. Not terrible... The plates are 503. The original schematic calls for 435. The 7591A screens are only rated for 440. It's already killed a pair in short order. The big resistor will create extra sag and a fair amount of heat. I've used the zeners before but never had any noise problems. Thanks.
You posted a stock schematic. Does the amp have a safety ground and the death cap removed? I don't know that it would make a difference (I actually don't) but I know I've never had any trouble doing it with a grounded chassis."Take two placebos, works twice as well." Enzo
As was stated here and el34 world, "Beware of gremlins if you put zeners on the CT of a fixed bias amp whose negative bias voltage has an AC source that also depends on that CT."
"Sorry I forgot to mention that potential problem. Glad sluckey did. It gets complicated fast. I think that you can still take your negative bias voltage off the PT secondaries, but if the zener on the center tap lowers the unregulated/unfiltered secondary voltage then you have to make changes to the bias circuit. You also have to pay attention to which "ground" you use for the bias circuit. That simple & cheap MOSFET circuit avoids those pitfalls."
Seems maybe putting the zener in line with the b+ might solve it.
Zener diode on B+ centertap has doubled bias supply voltage!
I do have an oscilloscope. I'll try grounding the center tap, but I'm not sure that will make a difference.
I guess the bias circuit could be the problem, but as I stated the hum goes away when I remove the phase inverter. So, the hum is being created or injected there, apparently. Thanks!
Originally posted by dstrat View Postwith out anything to drive the output tubes you will hear very little of anything, likely why it stops humming with PI tube pulled.
A wild guess would be a bad decoupling cap in the HV rail.?. Maybe the elevation is making some noise that isn't being shunted. It may even be that more filters should be replaced but the push/pull power amp is mitigating excess hum so you can't exactly hear some symptoms."Take two placebos, works twice as well." Enzo
