Page 1 of 2 12 LastLast
Results 1 to 35 of 38
Thread: Output tube snubber kits, any experience?
    Aug 2015
    Edmonton, AB
    99
    Received: 75/0
    Given: 39/0
    Like the title says...
    Anyone have experience with these snubber kits?
    Any good/worth it?
    The write-up "sounds good" or is this voodoo?
    https://www.amplifiedparts.com/produ...t-2-el84-tubes
    Old Timer
    Chill-Ville, VA
    2,593
    Received: 136/1
    Given: 273/6
    I would look it up in the RDH4. And that is considered a pretty dang reliable source. See what it says there, and see if it would make sense to apply it to a guitar amp.
    Now I'm curious...
    Justin
    Supporting Member
    Staffordshire UK
    3,426
    Received: 86/0
    Given: 83/0
    Quote Originally Posted by galaxiex View Post
    ...The write-up "sounds good" or is this voodoo?
    The writer's understanding of tube guitar amp operation differs considerably to mine
    Most every sentence seems to have some degree of error / nonsense.
    And which SF Fender models had OT protection diodes?
    But however flawed the technobabble, you may like the effect of the snubbers.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    Whatīs a typical EL84 PP impedance? 8k?
    IOF so, .0047uF across that will attenuate 4kHz about 6 dB.
    I wouldnīt call that "transparent"
    Not bad from a theoretical point of view, in practice it will be either a good thing (it kills buzz) or a bad thing (it kills sparkle).
    Npt used by any classic amp, but some Forumites often have the urge to "contribute something" and post these ideas, as well as cascode stages (never ever used in Guitar amps) and similar stuff.
    Pick your own poison, meaning try it and post results; experiment is real cheap-
    Typical of Net level information, they did not bother to post a schematic or explain operation, just mention the Word of God with zero detail or elaboration.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Well there's nothin' fancy about it except for the way it's wired (to look somehow symmetrical between the tubes?). See below.
    Other than that it's just a "conjunctive filter". Some guys hate that term, but it's the one we've come to know. You could wire it with a single 6k/5W resistor and a single 2200p cap for the exact same result. But then you wouldn't have those fancy Orange Drops and that symmetrical look that makes it seem like it's "balanced The truth is that very little consideration is given to this public offering WRT function because snubber circuits like this should take OT primary impedance into account and a scope should be employed for determining circuit values. It's just a masked face on an old circuit. But...
    Before you think I'm poo pooing the whole thing, I use a snubber filter on my own el84 design. Dr. Z seems to like them for el84's also and has done quite well with them. I use a 10k resistor and a 1500pf cap with an OT primary of 8k. I don't know what Dr. Z does.
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Juan, it's wired with the caps in series, so it's actually .00235uF with a 6k series resistance parallel to the OT. Even still, it is NOT transparent. The more conservative snubber I use is not transparent.
    EDIT: Just looking at the components again in the image. What a silly thing that is. Sort of like making a face on your plate out of your bacon and eggs for breakfast.
    Supporting Member
    Staffordshire UK
    3,426
    Received: 86/0
    Given: 83/0
    RDH4 reference on p567 https://archive.org/stream/bitsavers.../n607/mode/2up
    The seemingly pointless symmetry of the circuit may be due to it being kinda copied from the Dominator http://wem-owners.com/wp-content/upl...nator-sch1.pdf but the OT primary CT connection omitted.
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Indeed! The circuit values look similar enough considering standard values. I think R.G. mentioned (more than once) that he thought snubbing to the CT was better than snubbing the whole winding.
    One other thing about the "kit" that I don't like is the use of cement resistors. Their specs indicate they aren't the best choice for high voltage applications. I went with something called a "high energy" resistor that I found at Mouser. I can't remember what it was It was rated at 11W and I chose it for it's voltage rating. And OD caps aren't designed as snubbers. Punch enough holes in the film and foil construction and the cap becomes a short (ask me how I know ) I chose to use a cap designed as a snubber with a voltage rating of something like 2kV.
    Oct 2015
    NEPA
    578
    Received: 47/1
    Given: 39/0
    On the 18watt marshall forum, they use these "if" they have the problem of the output being fuzzy or fizzy or buzzy, however you want to describe it. It is a copy of the Watkins Dominator anyway as was said above. Solution looking for a problem?
    If you ran a freq response sweep of the output (or output and driver stage), you think any fizzy or fuzzy would show up? Maybe if using a speaker instead of a dummy load?
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Quote Originally Posted by mozz View Post
    Well the HF spike certainly shows up. The "ringing" mentioned in the write up for the kit is indeed common to 2xel84 designs. One problem with this is that with an actual speaker load the reflected impedance at these spike frequencies can be greater at the plates than the screens. So you can end up overdissipating the screens with sustained, extreme overdrive (ask me how I know ) That's the reason I use the snubber. Contrary to Zimmerman I don't recognize any "brick wall" effect from the Zeners. But then, it's not clear what circuit is being discussed or how the Zeners are implemented in his comparison. I use the Paul Ruby mod Zeners in combination with a bias clamp Zener with a self biased (cathode biased) circuit and my own criteria for tuning it. All I notice is a minimization of excessive crossover distortion. YMMV
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    A good read: Tubes
  12. #12
    Feb 2010
    10,200
    Received: 343/1
    Given: 672/0
    I've seen similar filters in some Garnet models, possibly Traynor also?
  13. #13
    Oct 2007
    10,291
    Received: 354/5
    Given: 356/5
    Best known and most respected EL84 user?: VOX AC30
    Do they sound good? .... you bet.
    Do they use snubbers? ..... are you kidding?
    Case closed.
  14. #14
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Love it Juan. And I might take it personal if my amp wasn't designed to do things the AC30 doesn't And, to be fair, the AC30 incorporates more than one slightly goofy circuit of it's own. In principal you're spot on though. If a player can't make music of almost any genre with an AC30 then what's it going to take.
  15. #15
    4,503
    Received: 116/0
    Given: 77/0
    Case closed.
    With the AC30 having a Cut control perhaps the need for a snubber circuit or conjunctive filter is reduced...?
    Steve A.
  16. #16
    Old Timer
    Chill-Ville, VA
    2,593
    Received: 136/1
    Given: 273/6
    But Chuck, don't your amps do thrash metal? I mean, never seen an AC 30 do THAT...
    Justin
  17. #17
    Aug 2015
    Edmonton, AB
    99
    Received: 75/0
    Given: 39/0
    Thanks for the great reply's!
    Just in case anyone missed it, here's the Guitar player article.
    Attached Files Attached Files
  18. #18
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Quote Originally Posted by Justin Thomas View Post
    Justin
    Maybe not "thrash". You really ARE better off with an uber drive preamp, then EQ and then a relatively clean power amp. That's the map to Wankerville. But my stuff isn't "smooth" like a *umble type sound either. More like if an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy.
  19. #19
    Old Timer
    Chill-Ville, VA
    2,593
    Received: 136/1
    Given: 273/6
    Oh, a Sovtek! (I still would rather have that Mig-100U than the '78 JMP 100W MV that had the JCM-800 front end)
    Clown-Shit-Crazy...
    Justin
  20. #20
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    If I had an amp for repair where someone had fitted components as per the instructions I'd want to cut it all out and build it up on tag strip. It looks like the mess you'd hang together just to see how it works before committing it to a proper build. Other than that, I'd only consider any kind of output filter if the amp actually needed it or if I was just curious to hear what something sounded like.
    The guitar world has plenty of products to fix things that aren't necessarily wrong in the first place. I went on a business seminar where one of the topics was "People are more willing to spend money on improving something they already have rather than buy new". The speaker went on to illustrate creating a perceived dissatisfaction with one aspect of a product, whilst promoting at the same time all the positive aspects. Then the closer was to sell a product or service that 'fixed' the problem.
  21. #21
    Dec 2009
    Devon, UK
    2,901
    Received: 157/0
    Given: 129/0
    I really don't think you would be seeing failures from high pulse current i = C. dv/dt as the 715P datasheet specifically mentions suitability for such applications orange-drop-datasheet.pdf.
    I suggest that excessive voltage would be the more likely culprit especially if you consider the energy comping back from the speaker. Those kV rated caps seem like the smart choice for that reason.
    BTW, those 8.2meg resistors are just a waste of space and money.
  22. #22
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Quote Originally Posted by nickb View Post
    I suspected the same due to the high value. But then I considered that maybe they are effectively balancing voltage at the very high frequencies being considered. But I don't know because that's out of my depth.
    I did turn a 600V 715P into a dead short in this application. I had only considered the measured HV and not peak voltages on spikes. Looking into it I found that some Dr. Z amps were also failing their shunt filters. I took what I thought to be practical measures to avoid that problem in the future.
  23. #23
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    382
    Received: 24/0
    Given: 35/0
    BTW, those 8.2meg resistors are just a waste of space and money. …
    Maybe they are there for civil engineering purposes - to help keep the thing up (in lieu of a proper tag-board).
  24. #24
    Oct 2007
    10,291
    Received: 354/5
    Given: 356/5
    Quote Originally Posted by Steve A. View Post
    Steve A.
    Probably .
    You donīt *really* need "protection" if you donīt visit the bad girls anyway
    Meaning in technical terms: if rise time of signal driving power tubes is *squashed* (what the Cut control does, and itīs always there, even if set to nominal 0 ) then they wonīt be excited into driving OT and speaker inductive impedance hard and fast, which causes ringing.
    So *maybe* AC30 does have a (sort of) conjunctive filter after all
  25. #25
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    755
    Received: 75/1
    Given: 47/0
    I'm the worst when it comes to this. But luckily Nickb is usually there to tell me to pull my head out of ass.
    But when you hear him say it, you'd think he's just respectfully offering some technical reasons why my idea may not be the best approach.
    Word on the street is, that you're one of go to cats for MusicMan amps in this joint. Would you consider that cathode drive circuit a cascode?
  26. #26
    Jan 2016
    Massachusetts
    755
    Received: 75/1
    Given: 47/0
    Hey! If it weren't for bad girls, there'd be only good girls.
  27. #27
    May 2007
    pacific north west
    13,432
    Received: 418/0
    Given: 455/0
    Quote Originally Posted by SoulFetish View Post
    I'll be the first to admit that I've danced with a few "bad girls". On three of a dozen designs of mine I've had to mitigate grid drive and balance screen current under tested drive conditions to find the "safe zone" and THEN take additional measures to tame potential problems under "extreme playing conditions" The "magic" of some of the old designs was how they could dance to that song without exploding... Often. So maybe those guys that we say "Never expected those amps to be cranked" were actually paying attention after all.?. It's occurred to me more than once. They were real deal engineers after all and this technology we consider old was all they were paying attention to! It would probably stun the best of us, what we DON'T know or have failed to account for.
  28. #28
    Oct 2007
    10,291
    Received: 354/5
    Given: 356/5
    ..... MusicMan amps in this joint. Would you consider that cathode drive circuit a cascode?
    Technically yes , although thatīs not the main point making it such a breakthrough.
    The real trick there lies in making a powerful Class AB2 amplifier, "hidden in plain sight".
    They can smash those grids with some 20mA on demand, any day of the week.
    Grids can get as much as as 20 or 25V *positive* on them.
    Al this goes well beyond any classical Cascode design, which usually delves only in relatively tame Class A1 .
    So yes, the Music Man power stage is a Cascode.
    But I was talking about Preamps, voltage gain stages.
    No Guitar amp I know of used them, my comment/rant went to lots of DIY designs using them, most using Fets after Jack Orman got undeserved appraisal after he published as his own a Fet Cascode straight out of Siliconix (or similar oldtimer disappeared Semiconductor manufacturer) datasheet or App note.
    It was published as AMZ Minibooster and caught like wildfire.
    Soon after, everybody and his Brother started using it as a gain stage, thinking it equals a standard tube gain stage , which it does not, and then looping the loop a few designers started porting it back to the Tube World.
    Just one example of the today common Cascode application and what they claim:
  29. #29
    4,503
    Received: 116/0
    Given: 77/0
    Probably .
    FWIW I like to wire up Cut controls on pots with a rotary on/off switch so I can remove them from the circuit completely if desired. I like being able to fine tune the power amp section to accommodate the frequency response of your speakers. (Right now my favorite "go to" speaker is the WGS ET65 which can be a bit bright. It is their version of the Celestion 12-65 at half the price. BTW many of the WGS speakers are now sold by GC/MF with free shipping when you meet their minimum- one of my big complaints about ordering from WGS was their shipping charges.)
    Steve A.
  30. #30
    Oct 2007
    10,291
    Received: 354/5
    Given: 356/5
    I guess WGS has to ship that individual speaker from their warehouse to your home, obviously using Mail or some commercial carrier, and pay full price end to end, while since GC has branches all over the place and has to supply them anyway, using their own distribution system to a nearby shop (95% of the trip) and then "a little more" to your home, way lower cost which can be absorbed even inside a narrow profit margin.
    OR, being a high volume shipper, they have an incredibly good deal with standard mail/freight carriers.
  31. #31
    Jan 2016
    Massachusetts
    755
    Received: 75/1
    Given: 47/0
  32. #32
    Jun 2007
    609
    Received: 2/0
    Some guitar amps that use cascode: Vox V125 Lead, Ibanez Starfield series, Marshall 9001 preamp, to name a few. Of course they are bass amps but Aguilar’s DB750 and DB659 also employ multitude of cascode stages. They are not an extreme rarity.
    Of course the cascode is a poor choice if you actually want to capture characteristics of a single-ended triode gain stage since cascode’s going to have characteristics more similar to push-pull topologies. I think its commonly employed with FETs mainly because it minimizes struggles to match them. Not to mention it clips "softly" like tubes reputedly do (though it actually clips too soft and too symmetrically compared to generic SE common cathode circuit).
    Back to real topic: I can instantly mention one “classic” tube amp with “conjunctive filter” and that is Dr Z’s Carmen Ghia. …Excuse me, (cough cough) I mean Hammond AO-35. There are some other vintage (guitar) amps where you can see the circuit used as well (though I wouldn’t consider them classics) and yes, Radiotron Handbook does explain why the circuit is used so it’s not just some snake oil.
    Almost every solid-state amp will have such circuit too, as it is basically nothing but a “Zobel network” that compensates for increasing load inductance at high frequencies by adding parallel capacitance (and a current-limiting resistor). Can make marvels to overall stability and yes, by doing so also reduce the fizzyness of overdrive characteristics and crossover distortion. In some cases (such as this “snubber” –thingy) the circuit is tuned to operate at audio spectrum and plainly acts as a low-pass filter so yes, it removes even more fizzyness.
    You will more likely encounter a conjuncctive filter in a tube HIFI amp than in a tube guitar amp, but yeah, most tube GUITAR amps do not even try to reach design extents of HiFi amps. They just pretty much use the simplest circuit that still works with modest reliability. But sometimes one needs to add a conjective filter to achieve that goal (e.g. Carmen Ghia).
  33. #33
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 13/0
    Probably the most popular amp that uses it is the Pro Junior.
    http://www.thetubestore.com/lib/thet...atic-Rev-F.pdf
  34. #34
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    Just picked up on this thread in my wanderings. The 8.2Meg resistors are most likely there to balance the voltage across the two caps. If the caps have unequal leakage then the voltage across them is shared according to their leakages. I've had to use the same setup when putting 800V across a pair of larger caps in the past, (to be dropped in the sea and towed behind a boat no less). As a rule of thumb the current through the resistors is made to be about 10x the maximum leakage so it swamps the current leaking through the caps and sets the voltage levels across each. In the article it actually says "The two lower-power resistors essentially spread the voltage evenly across the two capacitors". Now whether that is necessary given the fact that you can't find a quoted level for leakage for an orange drop capacitor is open to argument but it is a nice detail to get right.
    As to the JFET mu-amp based diagram posted by JMF, it definitely isn't a cascode. That example has the upper JFET stuck on as the load of the lower and the output taken from below it. A cascode utilises a second transistor to isolate the first (usually lower) from the output at its drain. Considering it as it is for BJTs, the second is a low input impedance common base stage acting as the collector load of the first and hence giving it a very low gain. In this way bandwidth is increased significantly by isolation from the Miller capacitance. The common base has a current gain of ~1 so keeps the gain of the stage as it uses the same collector load resistor as before. That circuit isn't even a mu-amp setup. It's really a SRPP with a dodgy output take off point, (or perhaps SEPP, see the reference to your own Merlin's site below).
    It's always a question to me whether the diagrams you see for effects pedals using the so called mu-amp circuits are correct and as the designer intended or whether they have suffered as most seem to do from taking the output of each stage from the wrong point. If that additional upper source resistor is included, and it does a lot of good there, is there some benefit I can't see in taking the output from its lower end? If the output is taken direct from the source of the upper FET at the top of the resistor, gain is increased significantly and output impedance is dropped greatly. Now that gain increase might not be what is wanted but then surely gain could be better controlled in the lower source or, at least, the resistor becomes a bit redundant. It is no longer isolating the lower stage from the output.
    See here for Merlin's analysis of the circuit in a valve context: http://www.valvewizard.co.uk/SRPP_Blencowe.pdf and here for the SS equivalent http://www.geofex.com/Article_Folder...p/modmuamp.htm
    I know many here are pretty much expert in this field but I'm sure many are not and theses do make an interesting read.
  35. #35
    Mar 2018
    Germany
    459
    Received: 189/1
    Given: 139/1
    If you are referring to the stage consisting of T3/T4 in JMF's example, this is indeed a SRPP amp ("shunt regulated push-pull", admittedly a strange and somewhat misleading name) and not a cascode or ĩ-amp. It is a real push-pull stage and the upper device is driven by the signal drop across R11. In a ĩ-amp the upper device has no drive signal and just acts as a high impedance active load to the lower one, making it a single ended stage with high voltage gain.
    - Own Opinions Only -
  1. Any experience with this tube vendor?
    By Aldo in forum Tubes (Valves)
    Last Post: 07-15-2012, 02:02 AM
  2. assembled kits of tube guitar amp
    By kldguitar in forum Kit Amps
    Last Post: 12-31-2010, 09:45 AM
  3. assembled kits of tube guitar amp
    By kldguitar in forum Flea Market
    Last Post: 09-19-2010, 05:47 AM
  4. Hi Fi Tube Kits
    By chunkitup in forum Build Your Amp
    Last Post: 10-05-2009, 05:58 AM
  5. assembly kits of tube guitar amp
    Last Post: 09-09-2009, 12:00 PM
