Results 1 to 2 of 2
Thread: Dimensional tolerances for a back panel?
    Supporting Member
    Feb 2007
    Seattle WA
    408
    Received: 32/0
    Given: 2/0
    13
    I am going to build a back panel for a Fender Showman amplifier. I am going to build one because the place I was going to order from has a long lead time and is rather expensive. Plus I have scrap hardboard and tolex just lying around my workshop.
    How short should I cut the wood panel to allow for tolex and fitting tolerance?
    For example if the panel is 20-1/2" by 6-1/2", what size wood panel should I cut?
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,458
    Received: 2,427/4
    Given: 2,811/0
    30
    What is the thickness of the Tolex? So it's the space width + Tolex thickness + a fraction to allow for a gap. You'll want to allow for a small gap between the Tolexed panel and the side wall just to insure against any audible vibration. I use thin shims when I set cabinet panels to evenly space a tiny gap for this reason. You can secure it tightly at the faces, but the edges are a crap shoot if you don't set a space or fit it tightly. A space is easier to do since it can be off a little without much consequence.
  1. Super Six Back Panel
    By The Dude in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-12-2016, 07:27 PM
  2. back panel shield
    By 59tone in forum 5 E 3
    Last Post: 04-13-2011, 01:35 AM
  3. Replies: 4
    Last Post: 05-12-2010, 06:13 AM
  4. Replies: 1
    Last Post: 03-11-2007, 04:54 PM
  5. Help sourcing back panel for tweed cab
    By jlatrace in forum Cabinetry
    Last Post: 02-02-2007, 03:00 PM
