Looking for a schematic for an Alamo Montclair 2565
  • Looking for a schematic for an Alamo Montclair 2565
    Acquired an Alamo in a trade, trying to restore it. The reverb is toast so I'm looking for parts. The schematic I need is for the one transistor, reverb and tremolo, 2 channel version of the 2565. Any help would be greatly appreciated.
    Welcome to the place!
    I found and tweaked this. It may or may not be of help. It's a blurry scan.
      I literally just found this. I’ll pass it on the my amp guy and see if it helps. Thanks!
        Amp guy looks at it and said it wasn’t tube schematics, but transistors. Back to the hunt I guess.
          Well, that schematic shows 2 output tubes and a PI tube. How many tubes are in your amp and what tube type?
            see if any of these work for you: Alamo Schematics - Tube amp Schematics
              6v6 x 2
              12ax7
              719o
              5y3
                so this one from that list.
                http://el34world.com/charts/Schemati..._montclair.pdf
                Problem maybe getting the 7199 tube if it is no good, but lots of articles around the web about using 6GH8, 6AN8, 6BL8, ECF80, ECF82, 6U8 in the place of a 7199, but most of these require swapping some wires connections on the tube socket.
                Ian
