Here in my region they began fining energy consumers who had a lot of reactive power on their bills. It's government-run eletrical utility and as such they'll find a way to fine you for everything. They installed electronic measuring systems and the electronics can detect reactive power where the old magnetic wheel meters did not detect anything. So this upgrade generated a immense wave of fines - a lots of work for electricians, some of whom are good friends of mine and made a nice buck installing capacitor banks for bars, restaurants and such which were the first targets of massive reactive consumption fines.
Well this gave me the opportunity to learn about power factor correction capacitors, which are heavy duty non polarized caps.
What I learned is that capacitors are actually rated for reactive power. These PF correction caps have a KVAR, or KVA-reactive, rating which is how much inrush reactive current x voltage reactive it can handle. In the world of amplifiers we're used to thinking that caps can simply handle whatever we throw at them as long as voltage is fine, but that's not the case at all, the reactive power is what's important. A tiny 50 uF capacitor will not be able to handle the same inrush current as a big bulky 50uF capacitor rated for the same voltage.
The caps they use for PF correction have escape valves which let out excessive pressure built into the cap during high load operation, because caps aren't perfect they do heat and let out vapor. We don't have this on amplifier caps, thus we see the bulge on top of caps that've been through abuse.
All in all messing around with higher power electrical caps taught me a lot about amplifier caps. The 3 phase voltage here is 380 V star configuration, with each phase having 220 VAC. PFC caps are rated 500V, giving them over 30% margin. So for whatever standard they're following, +30% seems to be their safety margin for 24x7 utility capacitors. You should apply at least the same to amplifier caps IMO, if your peak voltage, without power tubes on, is 500V then your totem should handle at least 650 to 700 VDC.
Reactive power is fascinating, it heats the wires, creates a mess if you don't do it right and will knock circuit breakers right out, all while producing nothing. Reactive power produces nothing, it's just there to fill the capacitors and inductors so they can function. Fluorescent lamps, refrigerators, SMPS and every single wall wart from computers to phones you plug in these days produces reactive power. Eventually everyone will need to learn more about these tin can beasts called power factor correction capacitors.
