Results 1 to 15 of 15
Thread: Tips for soldering to Brass with an iron
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,123
    Received: 27/0
    Given: 29/0
    12
    Any tips to soldering to a brass baseplate as my skills with this is not up to par when using irons/Gun . feel free to comment .
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,043
    Received: 679/32
    Given: 649/14
    21
    Clean the surface with sand paper, scotch bright, steel wool, or dremel tool!
    Pre-tin the surface with a good solder like kester 44.
    The main thing is to have a iron and tip that gets hot enough.
    Solder with quick hot iron!
    GL,
    T
    It's only Rock and Roll, but I like it!
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,294
    Received: 1,266/5
    Given: 1,378/0
    28
    HOT! Exactly. Then FAST! The idea is that you need to heat the spot where the brass will be soldered fast enough that the rest of the plate doesn't wick heat off that spot before it reaches flow temperature. Then you have to get in and get out because you probably don't want to heat the plate all that much and you don't want to boil the solder. I don't know what T uses. For amp chassis I've used a big Weller gun. That seems like overkill for this, but maybe a higher single wattage solder pencil in the 50W/60W range?
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,706
    Received: 797/15
    Given: 833/0
    12
    Quote Originally Posted by big_teee View Post
    Agreed, and an iron that stays hot enough if you're soldering a large or heavy gauge piece of brass. The 80W Weller "pencil" iron with a big heavy tip is my go-to tool for brass sheet, and even makes soldering direct to chassis a breeze.
    Chuck, that's right, FAST! And BULBOUS! And also TAPERED!
    May 2007
    pacific north west
    14,294
    Received: 1,266/5
    Given: 1,378/0
    28
    The 80W Weller "pencil" iron with a big heavy tip is my go-to tool for brass sheet,..
    Heat momentum
    Aug 2015
    Edmonton, AB
    180
    Received: 164/3
    Given: 94/3
    4
    Yes!!!
    I have that Weller.
    It's great for soldering/un-soldering wires and cap cans to even a thick steel chassis.
    Heat momentum indeed!
    Member jack briggs's Avatar
    Oct 2007
    Raleigh
    262
    Received: 1/0
    Given: 6/0
    12
    That's the iron I use for humbucker covers as well. In and out as quickly as possible is the key.
    cheers,
    Sep 2012
    Dogpatch-on-Hudson
    5,706
    Received: 797/15
    Given: 833/0
    12
    Quote Originally Posted by galaxiex View Post
    Yes!!!
    I have that Weller.
    The price is nice too, and I think you can still score them under $35. I got mine well-used from a stained glass builder 31 years ago. (Thank you Diane!) In spite of an AC cable on its last legs, it still keeps on truckin'. And when that cable finally goes, I got a spare in my soldering-gear drawer. Everybody should have one. They come in 120 and 160W versions too, for those really BIG jobs.
    May 2007
    pacific north west
    14,294
    Received: 1,266/5
    Given: 1,378/0
    28
    Well if the 80W will handle solder blobs on steel chassis, what qualifies as a "BIG" job?!? Opening canned good without a can opener while simultaneously cooking the contents?
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,843
    Received: 997/15
    Given: 726/23
    25
    Why do you call it "pencil" iron?
    For me pencil means:
    what do you call *this* , which is what´s actually needed?:
    I call it the (old style) soldering iron, the word "pencil" is not even close to describe it.
    In fact, given the size/weight you do not even*grab* it "like a pencil"
    In any case, you need lots of hot copper mass so heat transfers quick and you have solder melting temperature in a second or two.
    Jun 2009
    2,123
    Received: 27/0
    Given: 29/0
    12
    I see & I've followed some advice here to clean the part by sanding & add flux the quickly solder it works best , for this I using the Weller 100/140w soldering Gun.
  12. #12
    Sep 2012
    Dogpatch-on-Hudson
    5,706
    Received: 797/15
    Given: 833/0
    12
    For want of a better term. The 80 or 120 or 160W Wellers in linear form look like giant "pencil" irons. OK maybe a proper "pencil" maxes out at 45W or so. I use the term to differentiate between those and the "pistol" style irons which are usually powered via induction while having a comparatively low mass tip made of square copper wire.
    And that iron with the bent tip? KOOL! We'll call that one the Bill Clinton model.
    That's why the "pistol" irons never worked for me in heavy duty applications. For some folks, they work just fine. Doesn't upset me in the least. Y'know what they say, "whatever works."
  13. #13
    Aug 2015
    Edmonton, AB
    180
    Received: 164/3
    Given: 94/3
    4
    The Weller 80 watter I have kinda looks like a big pencil...
  14. #14
    Jun 2006
    California, USA
    3,554
    Received: 128/0
    Given: 90/1
    16
    For fun here is a family photo of the "irons" I keep within reach of my bench.
Name:	Tom's Soldering Tools_01.JPG
    It is interesting to note that the mass of the business end of the soldering iron increases faster than the rated wattage. The Weller 100P usually gets the job done when I need to solder to a steel chassis. The big 125W iron was a $1.75 thrift store find. As discussed above, the mass of the tip is important. The big Weller 250W soldering gun has a small tip and that's why it does not do a good job soldering to a high mass item even though it has such a high power rating. There is a trick discussed to use that gun with a custom two probe tip to heat a chassis via current flow through the chassis but I have never needed to try that.
    Cheers,
    Tom
  15. #15
    Jun 2009
    2,123
    Received: 27/0
    Given: 29/0
    12
ID:	49695You need very little prep with this iron , Bought this old Stanley iron at an antique store & just dab & watch the flow on brass , my Weller 140/100 gun is a piece of crap & don't work so well as my 30 watt pencil iron .
  1. Hanging up the soldering iron
    By Mars Amp Repair in forum Music Electronics
    Last Post: 05-07-2012, 01:22 AM
  2. Soldering Iron Recommendations
    By greengriff in forum Build Your Amp
    Last Post: 05-07-2011, 04:23 PM
  3. A real soldering iron
    By Joe Gwinn in forum Pickup Makers
    Last Post: 10-27-2009, 01:15 PM
  4. soldering iron question.
    By 91sport_tn in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-27-2009, 09:28 PM
  5. How powerful of a soldering iron do I need..
    By ctcpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-27-2009, 06:20 AM
