Results 1 to 18 of 18
Thread: Feeding a SMPS with DC instead of mains
    Valvulados.com jmaf's Avatar
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    (I guess this qualifies as circuit bending? I came to post this under the lounge or offtopic stuff. Please move if wrong? Thanks!)
    A friend of mine built a 220 V DC battery. He's experimenting with some solar power stuff. (I've warned him about safety and 220 VDC with no circuit breaker at the terminals, he says he'll be careful.)
    So i had the idea that a SPMS' first thing is always a rectifier (right?), so....the 220V mains fed into it is immediately rectified before being oscillated?
    Is there any problem with feeding a switch mode PS with 220 VDC directly instead of 220 VAC RMS mains? Will it damage anything if used continuously with DC instead of mains?
    Dec 2009
    Devon, UK
    3,697
    Received: 864/1
    Given: 655/1
    14
    There are some things to think about when feeding DC. Don't forget a fuse, a common mode filter and some filter caps. The filter caps are partially to give a low impedance source at the switch and also to prevent EMI. Another consideration is the 220VAC will rectify to give about 300V DC. In other words 220V DC isn't enough and that can cause major problem if the switcher has not been designed to operate at that voltage.
    Another consideration is that some SMPS's (mainly lower voltage input ~120VAC types AFAIK) use a voltage doubler and that requires an AC input.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Quote Originally Posted by nickb View Post
    There are some things to think about when feeding DC. Don't forget a fuse, a common mode filter and some filter caps. The filter caps are partially to give a low impedance source at the switch and also to prevent EMI. Another consideration is the 220VAC will rectify to give about 330V DC. In other words 220V DC isn't enough and that can cause major problem if the switcher has not been designed to operate at that voltage.
    All great points indeed. Thank you.
    Supporting Member
    Aug 2017
    Portland, OR
    828
    Received: 296/1
    Given: 122/2
    3
    I actually think of SMPS as working MOSTLY on DC, but then again I was working in the PC industry where we pretty much assumed everthing to be DC. Don't know about at 220VDC though.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,940
    Received: 2,253/7
    55
    Yes, an SMPS is DC after the rectifier, but every PC I worked with plugged into the AC mains. Lap tops run on low DC.
    Supporting Member
    Aug 2017
    Portland, OR
    828
    Received: 296/1
    Given: 122/2
    3
    This is classic SMPS DC-DC conversion: https://en.wikipedia.org/wiki/Buck_converter
    32,940
    Received: 2,253/7
    55
    Ah, we may be talking past one another.
    Yes, that buck takes a DC voltage and works with it. But where did that DC come from? In our amps, the DC supply is switched off and on through the primary of a transformer. But that DC is made by rectifying the mains AC.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Thanks Enzo. Yeah this is definitely unconventional. I've never done it, though should be simple to test at the bench, problem is I'm not near the shop now. Can't test. So I wanted to bounce the idea off you guys before I mushroom-clouded a SMPS.
    Quote Originally Posted by glebert View Post
    This definitely a good analogy. What I'm asking about is just a buck converter after all, duh!
    I just gotta look for what nickb said about it having some AC-only circuit at the input, doubler and so on. Other than that should be cookbook buck converter.
    I got off the phone with some more feedback, he said it's a 90 to 240 VAC automatic SMPS, so the other problem nickb said about it working on lower voltage won't be an issue I guess, probably has a voltage controlled oscillator that'll increase PWM frequency for higher voltages or something like that.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Exactly. I'm thinking of injecting straight DC where the AC would be....where mains would be... Instead of pushing in 220 VAC I'd give it 220 VDC, the rectifier would be redundant...
    Sorry for double post, Enzo replied while I typed.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    220V DC and 220V AC are completely different.
    111V different to be precise.
    Now that I gave you the clue, YOU tell me why
    Proof you actually read and understood it
    I suggest you read a little on how Offline SMPS work, to save you reinventing the wheel time and time again.
    famous last words
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    108V different to be precise.
    Thanks for your input. nickb mentioned this too. But this supply has a voltage-controlled oscillator, it'll work with any voltage from 90 to 240 VAC.
    famous last words
    LOL
    But yeah I'm concerned. I told him so many times.
  12. #12
    May 2018
    San Diego, CA
    61
    Received: 37/6
    Given: 16/3
    2
    You should be fine with DC input if this SMPS is less than 65W.......
    Over 65W then you have Power Factor Correction on the front end of the switcher....depending on circuit used you should be OK..
    Best to get schematic..
    I recently designed a 5kW SMPS for a MIL application....
    One requirement was that it needed to accept both AC or DC input...
    The AC input frequency range had to be huge...DC to 100kHz ...
    The 90V to 240V range is standard for commercial SMPS... For Dell I designed them from 80 to 300V to account for India's wild grid voltage swings...
    The frequency usually is fixed on most commercial SMPS....It's the Duty cycle range that changes...
    It becomes tricky at very low duty cycle , less than 10%, to control the inner current loop, so instead the Off-Time ramp is used to predict the On-Time slope ....
    Best to get a schematic....
    Can you vary this 220V DC you have planned to use ??
  13. #13
    Supporting Member
    Aug 2017
    Portland, OR
    828
    Received: 296/1
    Given: 122/2
    3
    I think the 220VDC is a battery bank.
  14. #14
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Quote Originally Posted by cerrem View Post
    That's awesome info, thank you.
    I think he spot-soldered a ton of batteries together, I haven't seen it in person. I guess he could derive taps along the way if several DC levels are needed, assuming he didn't pot them in gook. Would lower voltage taps be useful somehow?
  15. #15
    Dec 2009
    Devon, UK
    3,697
    Received: 864/1
    Given: 655/1
    14
    Quote Originally Posted by jmaf View Post
    That does not mean there is not a doubler that is switched in as needed. Measure twice, cut once...
    1 Not allowed! Not allowed!
  16. #16
    Lifetime Member
    4,451
    Received: 446/1
    Given: 3/0
    21
    Solar power is generated in about half-volt units. The photovoltaic junctions are stacked in series to get you to battery charging voltages, generally 20V or so open circuit to charge 12V batteries, and higher to charge 24 or 48V batteries. Your friend is probably stacking a bunch of solar cell arrays to get up to 220V, or floating many of the arrays to charge each battery from a floating solar cell, but provide the power out as high voltage DC.
    The question keeps coming back - why? If the charging scheme is built on the idea of running switching power supplies from high voltage DC, you get all of the quirks mentioned above. Some SMPS use doublers, some use active power factor correction (which isn't generally a problem, but there are different variants to take into account) and others will happily run on DC fed in. Pretty much, you're going to have to know the schematic and operation of every SMPS you connect to this setup. Each one will have a potentially different set of quirks.
    The solar power industry is built on the idea of putting solar-collected energy into the cheapest mass electrical storage available, then converting that to usable standard AC as efficiently as possible. That has amounted to arrays of lead-acid batteries for availability and cost reasons, although advancing lithium battery tech is getting there. This approach uses power inverters to make standard AC power from variable DC power. It trades off some inefficiency in converting twice, once to AC standard power, and again to the thing being powered, for ease and low cost of storage.
    If you're going with stacked, high voltage battery storage, you get the same problems unless you can eliminate a conversion step, and you take on the additional problem of now having to tinker and select for things that accidentally can be powered by high voltage DC. It gets a lot more special-cased.
  17. #17
    Aug 2012
    Great Black Swamp
    2,316
    Received: 482/0
    Given: 1,298/1
    11
    With the special case argument presented, I wonder what 'special case' you are solving for by using a SMPS?
    If your solar-power friend is looking to get 110 or 220 VAC line power to run his home/camper/mars rover then maybe an "off the shelf" variable frequency drive would work. Most modern units have AC line inputs to the rectifier, but also DC bus connections specifically designed for load sharing. You still need to size it for the expected max load and minimum expected DC voltage, but that's minor compared to the minutia discussed above. Try looking at VFDs made by Yaskawa for starters. Generally low-cost and available.
  18. #18
    Dec 2009
    Devon, UK
    3,697
    Received: 864/1
    Given: 655/1
    14
    There are plenty of off the shelf solar -> battery -> AC inverters on the market for off-grid applications. That's the way I would go. Once you've got a standard distribution voltage and frequency it's easy to hook to other things.
  1. Sunn T50c feeding back without a guitar plugged in
    By dan.blackburn in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2018, 12:22 AM
  2. Help with Virtual earth mixer feeding a Cathodyne PI
    By walkman in forum Theory & Design
    Last Post: 08-23-2012, 04:25 AM
  3. Replies: 27
    Last Post: 11-26-2010, 09:21 PM
  4. Why is the gain control a pot feeding the signal to earth
    By Numpticious in forum Theory & Design
    Last Post: 08-25-2008, 11:49 AM
  5. OT transformer feeding back
    By jreese2001 in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-17-2008, 12:16 AM
