Results 1 to 6 of 6
Thread: Original Sovtek 5881 (coin/wafer based)
  1. #1
    Join Date
    May 2018
    Location
    N.W. Europe
    Posts
    40
    Thumbs Up/Down
    Received: 6/0
    Given: 4/0
    Rep Power
    0
    Hello kind folk.
    I recently purchased a quad of matched 5881, original Sovtek tubes - not branded Sovtek, but say 6n3c-e (in Russian of course). But I am unable to reliably find a datasheet for these particular tubes (the vender does not provide them) that print the maximum voltage allowance for anode and screens. One datasheet I did find said 250V (here), but printed as a side note and I am interpreting it as the voltage used in the test, as an operating parameter.
    This is the small wafer or coin based 5881. Can someone clue me in on that? Again, it's more to know for certain rather than to form an uneducated guess based on a google search.
    Thank you!!!!
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    Nov 2013
    Posts
    234
    Thumbs Up/Down
    Received: 65/1
    Given: 15/1
    Rep Power
    6
    these tubes are so sturdy you can use them in very high voltage/power amps (Soldano,Marshall) and never complain,i'd say the only thing to note is that max dissipation should be around 23W.
    Military radio stuff.
  3. #3
    Join Date
    May 2018
    Location
    N.W. Europe
    Posts
    40
    Thumbs Up/Down
    Received: 6/0
    Given: 4/0
    Rep Power
    0
    Quote Originally Posted by alexradium View Post
    Thank you! This is what I thought - but I couldn't find the evidence via a tube datasheet. In fact the same vendor was selling a set for a Dual Rec of the seemingly same tubes... but the answers I received from them were a bit less than clear - so I decided to turn to the awesome MEF forum.
  4. #4
    Old Timer
    Join Date
    May 2006
    Location
    Chill-Ville, VA
    Posts
    2,954
    Thumbs Up/Down
    Received: 513/4
    Given: 953/9
    Rep Power
    16
    Many have used these tubes in "torture chamber" amps, at voltages well above either spec on that "data sheet." And if you follow the 70% "Rule" for plate dissipation, you end up around 23W, anyway, and many consider these as equal to or better than a 6L6GC. Nobody really knows for sure, so the best can hope for is to have a bunch of people chime in and say "I did such&such and they were fine..." Or, wind the dissipation up & see what they'll take; I'm pretty sure they'll take any voltage you throw at them. Some empirical data from forum members would probably be welcomed.
    I also believe these were the ones sold as Sovtek 5881WXT, & that if you buy based on the GUTS and don't worry about the base, you get the sane tube.
    Justin
    1 Not allowed! Not allowed!
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  5. #5
    Join Date
    Feb 2010
    Location
    Posts
    11,208
    Thumbs Up/Down
    Received: 1,168/21
    Given: 2,957/8
    Rep Power
    22
    That is the only data sheet that was ever available for these tubes.
    I would not hesitate to try them in any circuit that calls for a 6L6GC (or lesser) type. They will survive, but will usually give less power output than an actual 6L6GC.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  6. #6
    Join Date
    May 2018
    Location
    N.W. Europe
    Posts
    40
    Thumbs Up/Down
    Received: 6/0
    Given: 4/0
    Rep Power
    0
    Thanks, Guys.
    I am relieved to get the answers here.
    For me, I am not so worried about output... as it is I can't even turn the volume past 9 o'clock, maybe 10 o'clock, before it blows your hat off. In addition, I love upping the volume to get some of that output midrange kicking in... maybe this will be a bonus in that aspect.
    However, for me it is function over form, but I do hope they sound as good as they are reportedly tough!
    Thank you!
Thread Information
Users Browsing this Thread
  1. JCM900 5881 to EL34
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-17-2019, 09:02 AM
  2. Replies: 27
    Last Post: 05-07-2010, 06:47 PM
  3. 5881 question
    By lowbrow in forum Tubes (Valves)
    Last Post: 12-23-2009, 02:19 AM
  4. Sovtek 5Y3GT and Sovtek 5V4G?
    By catnine in forum Theory & Design
    Last Post: 07-06-2009, 01:43 AM
  5. Real World 6P3S-EV/Sovtek "5881" test
    By steve in forum Theory & Design
    Last Post: 05-14-2007, 02:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
