Yamaha 5000-12 problem
  • Yamaha 5000-12 problem
    The amp turns on and the two channels show inputs but there is no sound from any input ......
    what is the problem?????
    Would that be an EMX5000-12?
    I assume you mean an input signal shows up on the VU meters but nothing comes from the speaker output connections? Then first thing I look for is blown fuses in the power amp circuits. And unfortunately, fuses usually blow for a reason, most common reason would be a failure of the power amp.
      thank you for the response
      yes it is an EMX..........How can I check the fuses ?????.........
      I don't hear the fan running either ......and I understand that could lead to overheat .....
      so where do I start ?
        thanks for the response ..........how do I check the fuses?????..........
        would the fuses blow if the fan stopped running ???
        does the fan have a fuse ???
