Results 1 to 8 of 8
Thread: telling unmarked preamp tubes apart
  1. #1
    Supporting Member Randall's Avatar
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,272
    Thumbs Up/Down
    Received: 441/0
    Given: 80/0
    Rep Power
    9
    I have about 7 or 8 12AX? tubes with no detectable markings. I have always wondered if there is a way to determine how much gain is there and maybe decide if it is a 12AX7, 12AY7, 12AU7, etc?
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    May 2018
    Location
    San Diego, CA
    Posts
    61
    Thumbs Up/Down
    Received: 37/6
    Given: 16/3
    Rep Power
    2
    Quote Originally Posted by Randall View Post
    Without a tube tester it can be tricky.... Since visually the plate structure is usually identical for both halves of these types of tubes... just a change in grid wire geometry such as turn-per-turn spacing and turn angle is all that separates a U from and X and T ..
    You can install them into an amplifier and measure the bias and operating voltages and possible signal gain at the anode.. Then compare these numbers against a good known "labeled" tube of that same type...
    Then take into consideration the variances ....just to get you into the ballpark...
  3. #3
    Old Timer
    Join Date
    May 2006
    Location
    Chill-Ville, VA
    Posts
    3,054
    Thumbs Up/Down
    Received: 610/6
    Given: 1,127/9
    Rep Power
    17
    Best amp for this purpose is a Champ - only one preamp tube. Easy to sort for gain.
    Assuming that you know they are indeed 12A_7 types; my issue is, I have 6EU7s and such floating around...
    Justin
    1 Not allowed! Not allowed!
  4. #4
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,832
    Thumbs Up/Down
    Received: 455/2
    Given: 238/0
    Rep Power
    25
    Set up an amp with 12AX7's that you know works.
    Feed it a signal, set it for clean & scope the output of the amp.
    Don't move anything.
    Install the unknown tubes and measure the output on the scope.
    Here is a nice gain comparison chart.: http://www.300guitars.com/articles/p...itution-chart/
    Be aware that this cheap ass test is a guide.
    Basically you are guessing.
    I have seen 12AT7 tubes with the same gain as a 12AX7.
  5. #5
    Join Date
    Aug 2017
    Location
    Portland, OR
    Posts
    604
    Thumbs Up/Down
    Received: 192/1
    Given: 89/2
    Rep Power
    3
    There are some tricks to see faded markings that you can't see otherwise. I know holding them over a steaming pot can make lettering visible, there are a couple other ways as well.
  6. #6
    Supporting Member mozz's Avatar
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    808
    Thumbs Up/Down
    Received: 182/1
    Given: 128/0
    Rep Power
    4
    6EU7 you can tell by filaments on pins 1 and 2 with a ohm meter. I have a hundred or so tubes with no markings. I was gonna start a thread with pictures trying to narrow them down.
  7. #7
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,988
    Thumbs Up/Down
    Received: 2,030/4
    Given: 2,318/0
    Rep Power
    29
    gelbert is onto it. I've bought many UOS tubes at a salvage warehouse I use to haunt and if you wear good readers and tilt the tube in good light you will usually see markings that seem to be sort of etched in the glass. You may find yourself looking up crossover numbers to determine what something like 7729 or 5814 mean. Otherwise do as Jazz said. I have known good examples of x7, u7, y7 and t7 I could use as base lines for such a test. Hopefully you do to.
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  8. #8
    Join Date
    Dec 2008
    Posts
    785
    Thumbs Up/Down
    Received: 21/1
    Given: 4/0
    Rep Power
    11
    Those of us who've seen a lot of them or have marked examples handy can sometimes identify a tube brand if there are distinctive structures.
    For example, GE and Sylvania tended to use "box" plates for 12AX7s. Telefunkens look like Telefunkens. Amperex and Mullard have identifying details. RCA and vintage Tung-Sol can be a little tricky to tell apart unless you have examples.
    12AY7s are relatively rare. If there's doubt about whether something is a 12AX7 or a 6EU7, you can look inside to see where the heaters are connected.
Thread Information
Users Browsing this Thread
  1. I'm not telling guys this
    By Randall in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-06-2017, 05:22 PM
  2. Replies: 16
    Last Post: 07-23-2014, 02:11 AM
  3. Unmarked mystery cap can
    By Resonator Guy in forum Repair and Restoration
    Last Post: 03-26-2014, 05:00 PM
  4. What is my meter telling me?
    By Edward R in forum Pickup Makers
    Last Post: 11-28-2009, 11:35 PM
  5. Best preamp tubes
    By bluesaholic in forum 5 E 3
    Last Post: 01-28-2008, 06:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
