Results 1 to 3 of 3
Thread: Crate Palomino V32h - wrong DC voltages - V3 tube issue
    New Member
    Feb 2017
    4
    0
    Unhappy Crate Palomino V32h - wrong DC voltages - V3 tube issue
    Hello there,
    I have issues with my Crate V32h Palomino i can't seem to understand. Long story short:
    Amp is 20+ years old and had an issue with an electrolytic cap in the preamp section, which I fixed. I then decided to do a recap of most electrolytics and some non polarized, since I had a surplus of parts. (mostly Nichicons with a higher temp rating). I'm a novice but quickly learning.
    The DC voltages for the first 2 preamp 12ax7 tubes test OK.
    V3 is showing these values for DC:
    Pin 1 says 215V but I measure 250V.
    Pin 6 says 210V but I measure 50V.
    I replaced all of the caps highlighted in yellow (C13, C14, C30, C39, C15, C16, C4 & C8)
    The DC on one side of R11 measures 275V correctly. C4 is also measuring 260V correctly.
    As far as symptoms, i have an almost unnoticeable crackling every now and then, but could be from preamp. I don't know what other symptoms to look for... more volume? is this normal? Bad Resistors/Bad Caps/power tubes?
    Attached Files Attached Files
    Nov 2013
    345
    Received: 130/11
    Given: 45/0
    7
    try substitute V3 with a new good tube,if nothing changes most probably the plate resistors are bad
    Feb 2010
    12,641
    Received: 2,186/24
    Given: 5,509/11
    24
    Also post the DC voltages for pins 3 and 8 of V3.
  1. Crate palomino v32 V1 tube not lighting up help
    By tonefiend in forum Guitar Amps
    Last Post: 01-21-2015, 10:04 PM
  2. Ampeg V3 voltages high
    By Randall in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-07-2014, 01:31 AM
  3. Metro JTM45 V3 PI VDC voltages VERY high!
    By QuestionMark in forum Guitar Amps
    Last Post: 03-13-2014, 01:10 AM
  4. Valve Junior V3 Head input mod gone wrong...
    By rgvkiwi in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-14-2009, 05:57 PM
  5. Crate Palomino?
    By OldFarb in forum Guitar Amps
    Last Post: 11-07-2007, 04:21 AM
Tags for this Thread
