Strange issue after the amp is turned on, warmed up and the volume set to just about any level. If a string or a chord is struck or strummed the output level sounds a bit weak. If done again but this time the strings are struck or strummed harder the output level jumps up and stays there. Not talking about the volume going up because the strings are being hit harder, the actual output volume of the amp goes up. If the amp is shut down for a while and turned back on it does the same thing.
If I remember correctly this amp has never been touched and is in great condition, everything inside is original and in good condition. I haven't been inside it in a while. It is here again but I haven't opened it up. The owner is not sure if he wants it gone through and recapped and anything else done other than the weird volume issue. Due to the condition of the amp, he does not use it to play out, just for practice.
