Results 1 to 9 of 9
Thread: Installing a pickup on a Dobro?
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    3,030
    Received: 320/0
    Given: 34/1
    16
    Has anyone got any suggestions on how to put a pickup on one of these. From reading it seems the best and least invasive way is to put a quality piezo disc on the resonator. Has anyone here ever done it? Any tips or suggestions. I donít want to mess this one up!Click image for larger version.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,503
    Received: 917/32
    Given: 895/14
    22
    If you do a search for electric dobro, or electric resonator guitar?
    https://www.google.com/search?q=elec...mgIwBQ#imgrc=_
    Looks like the standard place is at the neck.
    I wound and installed a pickup for one once, but the hole was already routed at the neck.
    GL,
    T
    "You can't promote principled anti-corruption action without pissing off corrupt people!" Diplomat George Kent
    Dec 2007
    3,030
    Received: 320/0
    Given: 34/1
    16
    Quote Originally Posted by big_teee View Post
    GL,
    T
    Thanks for your response BT... yes I did a search... several. Yes sandwiching a piezo element in the neck pocket is a common practice. Iíve seen it done on Strats and Teles to try to get an ďacousticĒ sound. I actually have a ďthin bodyĒ electric resonator that has a mini humbucker near the neck, a piezo (I believe) in the neck pocket, and a blend pot. Its... ok... from my reasearch it seem that the preferred method for a metal Dobro like this is to attach a quality piezo disc directly to the reasonator disc and use an end pin jack and preamp. The problem I see is the PLACEMENT of the element on the reasonator surface. These things are a real bitch to disassemble and put back together. I need to get the placement correct the first time. So Iím looking for someone who has done it before.
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,667
    Received: 365/6
    Given: 358/1
    12
    Here's an opinion from a resophonic builder:
    For an awesome electric tone, install a P90; to sound like a resonator guitar, use a mic.
    http://muleresophonic.com/just-use-mic/
    -rb
    DON'T FEED THE TROLLS!
    Member Emeritus Forever Steve A.'s Avatar
    4,506
    Received: 129/0
    Given: 77/0
    18
    Quote Originally Posted by olddawg View Post
    Has anyone got any suggestions on how to put a pickup on one of these. From reading it seems the best and least invasive way is to put a quality piezo disc on the resonator. Has anyone here ever done it? Any tips or suggestions. I don’t want to mess this one up!Click image for larger version.
    According to the Schatten site putting a piezo disc on the cone can create feedback problems. If the dobro has a spider bridge they have two different kits, one with a condensor mic and preamp.
    http://www.schattendesign.com/resonator.htm
    Steve A.
    Dec 2007
    3,030
    Received: 320/0
    Given: 34/1
    16
    Quote Originally Posted by Steve A. View Post
    Steve A.
    Thanks Steve... funny thing 5 minutes ago a luthier I know called me back and recommended this as the best option. I hadn't seen it searching. He said that the advantages this system has is the placement is finite and easy, it's minimally invasive, and it is not prone to feedback. The disadvantage is it has VERY low output even compared to a standard piezo. I think this is the one I am going to use.
    Old Timer
    Feb 2010
    2,667
    Received: 365/6
    Given: 358/1
    12
    But, but but... isn't that guitar a Duolian, with a biscuit bridge?
    Will the Schatten system be compatible?
    -rb
    Dec 2007
    3,030
    Received: 320/0
    Given: 34/1
    16
    Quote Originally Posted by rjb View Post
    -rb
    Yes it is a Duolian... but Shatten says they have a compatible pickup. I'm going to call them just to make sure. This is an early 90s long scale roundneck. I've never had it apart, just changed strings. From what I understand the whole reasonator assembly is mounted on one Central bolt. The Shatten pickup is like a big washer that is sandwiched between 2 nuts on that bolt. The luthier I use said he would install it for $100.
    Dec 2007
    3,030
    Received: 320/0
    Given: 34/1
    16
    For anyone thatís interested... this is a ďbiscuitĒ bridge. Schatten discontinued the pickup I was considering because some players said it muted the resonator a bit because of the mounting scheme. What they have now is something called the NR-2 or the NR-2 Pro. Itís a piezo strip that simply attaches to the bridge with double sided tape. I donít want to drill the body since you canít install an end pin jack for a jack mount. The Pro version has a little box with a jack and a volume control that you also mount with 2 sided 3M tape. I think this is the way Iím going to go...
    http://www.bluestarmusic.com/Schatte...me_p_1072.html
  1. Replies: 11
    Last Post: 06-17-2016, 08:05 AM
  2. Replies: 13
    Last Post: 09-25-2012, 08:31 AM
  3. Dobro Pickups
    By big_teee in forum Pickup Makers
    Last Post: 01-22-2011, 06:06 PM
  4. National Dobro Model 75- replace field coil speaker?
    By labeau in forum Music Electronics
    Last Post: 12-04-2009, 10:41 PM
  5. Installing a fan
    By MitchK in forum Mods & Tweaks
    Last Post: 11-20-2009, 01:17 PM
