Modifying 5F2A circuit for EZ80 and EL84
  • Modifying 5F2A circuit for EZ80 and EL84
    Hi - this is my first post for a while - so far I've built a 5E3 and a 5E5 based amp and they're both running beautifully.
    I'm building a 5W class A amp using the Fender Princeton 5F2A as a blueprint but with an EZ80 rectifier and an EL84 power valve. (I'm in the UK).
    The PT gives out 190-0-190 and there's just one 6.3v-0 heater tap at 2A.
    Question 1: Can I run the lamp (6.3V) and all the tube heaters off the 6.3v tap (pre-amp tube is 12AX7)
    Question 2: Do I need to alter any of the resistors or caps?
    Thanks in advance
    Stephen Hartley
    Heaters should be fine. Voltage should be ok, maybe a little low so you may not get the entire 5 watts output. You will have to change the el84 cathode resistor to get to the bias you want.
      Thanks very much. Should I be going up or down with the cathode resistor?
      Best wishes
      Stephen
        Down, the AC4 uses 150 ohms.
          Thanks - I'll give it a go
          Cheers
          Stephen
            I've read that if the EZ80 blows, it will send HT through the heater circuit and blows the tubes and transformer - is it reasonable to put a 2 or 3 amp fuse into the heater circuit for protection?
