Ugh..Idiot Jubilee hacked
  • Ugh..Idiot Jubilee hacked
    Marshall 2555 sounding bad, then I notice it was modded.
    Specifically the relay must have gone bad so it was replaced with the wrong pin-out one and modded to "work" but not correctly.
    Frakin' Idiot.
    I have the right pin out but too high a voltage.
    I'll see if I have any at work.
    If not, anyone know where to find replacements off the top of yer head?
    I know someone will ask, so, schematic?
    Justin
      Sure, if it makes you feel better
      There is no info on the relay on the schems.
        Here is a correct part for future reference.
        http://farnell.com//datasheets/14704...920.1516110160
          Ugh, what an idiot.
          So I got the relay and switching sorted out but hardly any volume.
          Because the loop jacks were wired wrong.
          That explains the mod I removed earlier which sent signal to the return loop amp.
