Results 1 to 14 of 14
Thread: Ampeg SVT 7 PRO U2 (ICE2A165) repair
  1. #1
    Junior Member
    Join Date
    Jan 2018
    Posts
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Hi all!
    I have a SVT-7 PRO over my workbench who simply don't work if I connect the Preamp Board (or another 12v charge).
    First to all, the amp came from another tech with a really bad mess with the U2 & asociated components of this PSU (practically all the PCB behind U2 was carbonized). I repair the mess with the carbonized section, replace the ICE for the big one (ICE2A265) and replace too all the PSU components next to U2; then I plug the AC cord (with a protection light bulb to prevent shorts) and the amp simply don't work at first.
    I disconect the Preamp section and again plug and switch to On and the Main Board works fine, with all the voltajes perfectly regulated, so I connect just the filaments of the 12AX7 to 15v and ground and again the PSU don't work, simply can't handle any other charge connected to +15v -15V. I probe the preamp & output boards on a working SVT7 PRO from a friend an the boards are all fine (and put the preamp and output SVT7 boards of my friends amp and don't work) so I know that they're working properly.
    Any suggestions to check the PSU section?
    Thanks in advanced...
    0 Not allowed! Not allowed!
  2. #2
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,060
    Thumbs Up/Down
    Received: 978/100
    Given: 141/35
    Rep Power
    11
    Quote Originally Posted by Khefer Kaos View Post
    Hi all!
    Do you have a spare 12ax7? So what happens if the 12ax7 is removed? Will it still power up? What are your voltages on the tube socket?
    nosaj
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  3. #3
    Junior Member
    Join Date
    Jan 2018
    Posts
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Quote Originally Posted by nosaj View Post
    nosaj
    Yeah, I probe anoher one, nothing changes. The amp came with a JJ 12ax7 who works fine too. The Main Supply doesnt work with or without 12ax7, just works if I disconect completely the preamp Board. Without preamp, all the Main voltajes go perfectly fine (+ -15 V, +300v, + -55v and -43v measures perfec). I conect the 12ax7 filaments directly to +15 and GND without conect the preamp board and the power supply doesnt start running.
    It's something weird haha...
  4. #4
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,060
    Thumbs Up/Down
    Received: 978/100
    Given: 141/35
    Rep Power
    11
    If I' understanding you correctly and I'm not sure I am.
    Your preamp board possibly still has a short on it.
    Also from what I understand SMPS power supplies do not generally like a dim bulb tester. You also need to be very careful with the smps supplies.
    Can you post any pics of the repair section?
    Thanks,
    Jason
    nosaj
  5. #5
    Junior Member
    Join Date
    Jan 2018
    Posts
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Thanks,
    Jason
    nosaj
    Ok, tomorrow I post some pics. The preamp is working right, I put it on another SVT7 and all are perfect, not shorts or malfunctions, just works like a new one...
  6. #6
    Junior Member
    Join Date
    Jan 2018
    Posts
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Sorry, I can't post photos, i don't know why. Whatever I follow doing some tests:
    I work the PSU without bulb dim, but with no differences, so again, disconection of +-15V (and even 300v to 12ax7) was the only way to work with.
    Putting an external power supply to the preamp was one solution (300v, +-15v), so whit this, the amp works great (ICE chip runs normaly and cold). So I'm thinking in let the PSU +-15 only supplying the power amp section and do another supply for the preamp.
    Any suggestions???
  7. #7
    Join Date
    Aug 2017
    Location
    Portland, OR
    Posts
    570
    Thumbs Up/Down
    Received: 174/1
    Given: 87/2
    Rep Power
    2
    My 7 Pro has had problems with U2, and I switched from a real tube to a Retrovalve FET replacement to get rid of the tube heater load. I actually like the sound better.
  8. #8
    Junior Member
    Join Date
    Jan 2018
    Posts
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Retrovalve FET its a "Solid State Valve"? One of the options on my mind, was to rid off the Valve and doing this stage with two fets and a bias of 4.5v like a valve emulator...
  9. #9
    Join Date
    Aug 2017
    Location
    Portland, OR
    Posts
    570
    Thumbs Up/Down
    Received: 174/1
    Given: 87/2
    Rep Power
    2
    Yes. http://www.robertsaudiotech.com/designs/retrovalve.php
    I find them really useful debug tools as well, rather than having some "golden 12AX7" or something. I have to say the LED bulb inside is a little bright if they were trying to emulate the soft glow of a tube heater.
  10. #10
    Join Date
    Aug 2007
    Location
    Richmond, VA
    Posts
    166
    Thumbs Up/Down
    Received: 11/0
    Given: 7/0
    Rep Power
    12
    Revision H01 SVT7
    H01
    New Power Management IC (U2)
    Current IC overheats. New IC ICE2A265 runs cooler.
    Replace U2 0026347 with 2046141.
    3 Not allowed! Not allowed!
  11. #11
    Join Date
    Feb 2017
    Location
    Lansing, MI
    Posts
    57
    Thumbs Up/Down
    Received: 3/0
    Given: 16/0
    Rep Power
    3
    I'm in Michigan looking at the exact same issue. Ampeg SVT7 with blown U2, open R46 and bad D9. Can I chime in with questions along this line or would you rather I start anew? Thanks, Mike
  12. #12
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,874
    Thumbs Up/Down
    Received: 1,923/4
    Given: 2,160/0
    Rep Power
    29
    To all that have been reporting this members posts... I believe there is a lack of adware blocking on their media and I don't perceive this as intentional spamming. Member checks out otherwise as far as I can tell.
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  13. #13
    Senior Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,655
    Thumbs Up/Down
    Received: 565/1
    Given: 1,309/1
    Rep Power
    11
    If this is in regards to the Retrovalve link, I found that an interesting device, never having seen them before. It does figure someone would have built such devices for commercial sale by now....I've just never come upon them before.
  14. #14
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,790
    Thumbs Up/Down
    Received: 429/2
    Given: 224/0
    Rep Power
    25
    1 Not allowed! Not allowed!
Thread Information
Users Browsing this Thread
  1. Please Help with a difficult Ampeg SVT PRO 4 repair
    By rickybocker in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-15-2016, 08:24 PM
  2. Ampeg SVT-3 Pro Repair help, R27 catches fire on power up
    By Barnaby Jones in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2015, 03:51 PM
  3. Ampeg SVT 4-Pro repair help
    By defunkmike in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-27-2014, 07:16 PM
  4. HELP!....Ampeg SVT 3 Pro
    By Don Wilson in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-10-2011, 05:15 PM
  5. Ampeg SVT-4 PRO repair amp output
    By tinchom23 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-12-2008, 11:30 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
