I have been using this for years. It works great and cleans up scratchy pots etc.. But it always leaves the pots feeling loose and cheap. I just sprayed some in some scratchy Fender Frontman 212r pots and they not only turn too loosely but they even wobble if I push side to side. The pots that I didnt spray do not do this. Is there something I should spray after D5 to tighten up the feel? Did the D5 just dissolve something crucial? Its does say safe on plastics so I'm not sure what to think here.
Deoxit D5
Originally posted by lowell View PostI have been using this for years. It works great and cleans up scratchy pots etc.. But it always leaves the pots feeling loose and cheap. I just sprayed some in some scratchy Fender Frontman 212r pots and they not only turn too loosely but they even wobble if I push side to side. The pots that I didnt spray do not do this. Is there something I should spray after D5 to tighten up the feel? Did the D5 just dissolve something crucial? Its does say safe on plastics so I'm not sure what to think here.
Sometimes the lube will harden to the point of freezing the control shaft. Back in the '70s Tapco had a big problem with this and had some sort of thinner to fix the problem.
I'd try and use as little cleaner as possible to make the control noise free, but not enough to dilute the lube.
Originally posted by lowell View PostI have been using this for years. It works great and cleans up scratchy pots etc.. But it always leaves the pots feeling loose and cheap. I just sprayed some in some scratchy Fender Frontman 212r pots and they not only turn too loosely but they even wobble if I push side to side. The pots that I didnt spray do not do this. Is there something I should spray after D5 to tighten up the feel? Did the D5 just dissolve something crucial? Its does say safe on plastics so I'm not sure what to think here.- Own Opinions Only -
Using the Spray version of Deoxit D5 can indeed cause that. I will normally remove/lift out the panel PCB, unsolder the pots carefully and either pry off the cover, and brush on the liquid version of Deoxit onto the resistive track & wiper wring mechanics so I don't upset the viscosity of the pot shaft/bushing. On pots that have the bushing assembly that will come off, I've been using Red bearing grease, applied with a shaved end of a wooden Q-tip. But, I haven't yet come up with a solution that you can spray into the shaft/bushing interface to restore the original viscosity. So, I too would love a solution to that. I've tried spraying DuPont's Teflon/Silicon lubricant into that joint, but have never been satisfied with the results. I haven't yet tried to heat some of the bearing grease to turn it into a liquid and try and seep it into the pot shaft/bushing joint, then exercise the shaft until it feels better. When it cools, you'd have a greased bushing. Maybe. That's as far as my thinking carries me this morning.Logic is an organized way of going wrong with confidence
Originally posted by drewl View PostModeration, just like everything else.This isn't the future I signed up for.
I actually prefer the easily spun pots myself.
While I could remove the pots, open them, do service to them, reassemble them, an reinstall them, that adds an hour or more labor, whereas the spray Deoxit is done within a minute, literally.Education is what you're left with after you have forgotten what you have learned.
The manufacturers spec the shaft torque don't they? I mean, if you order a batch of pots from Alpha or whoever, you get to spec how much force is required to turn the shaft, right? I'm thinking the manufacturer does not achieve this by adding more or less grease into the can, but by some other, mechanical means.
For vintage 60s pots, I use F100 (fader lube) or F5 if some solvent is needed. The pots always loosen up when sprayed and worked, and I've always seen this as a major benefit of the cleaning--that it cleans and relaxes that 50-year-old, congealed, dirty grease!
The manufacturers spec the shaft torque don't they? I mean, if you order a batch of pots from Alpha or whoever, you get to spec how much force is required to turn the shaft, right? I'm thinking the manufacturer does not achieve this by adding more or less grease into the can, but by some other, mechanical means.- Own Opinions Only -
Originally posted by Helmholtz View PostFor some new friction you may use felt washers between knobs and faceplate
It is possible to have way too little friction. One of my customers, about 25 years ago when the Blues Junior was a new thing, thought someone was playing tricks on him when the knobs were turning themselves while he played. He thought he was losing his mind. One day he watched closely while he was playing and saw them jiggle into new positions, then he was sure! "I'm NOT seeing this!" Ah but he was... A set of felt washers did the trick and saved him thousands of dollars at the psychiatrist.This isn't the future I signed up for.
Look up the Alps catalog. Unlike say Mouser where specific items are listed as in stock, Alps provides a list of feature options, and you them make up a part number with the exact features you want. Thinks like threaded bushing or not, type of shaft, support brackets or not, etc. If that is an option, it will be in the catalog.
Actually, the Tapco affair points it out. If the knobs get too stiff, they offered a solvent to loosen up the goo in the shaft housing.Education is what you're left with after you have forgotten what you have learned.
"Less is more" is pretty hard to do with these new "improved" dumbassed fire hose DeOxit spray cans. I often spray more than I intended to, even with their add on reduction tip.It's weird, because it WAS working fine.....
Originally posted by Randall View Post"Less is more" is pretty hard to do with these new "improved" dumbassed fire hose DeOxit spray cans. I often spray more than I intended to, even with their add on reduction tip.If it still won't get loud enough, it's probably broken. - Steve Conner
