Hello everyone, got a situation here. I ordered a chassis for a jt45 build. I was going to use my Mercury Magnetics Axiom jtm45-ri-p Power Transformer (center to center 2-1/2 x 3-1/8”) but it’s too small. The holes on the chassis are 2-78 by 3-5/8 which I believe is the metro-amp standard chassis size. So my questions are: what gives?? Is this PT special? Can anyone recommend a chassis that would fit or do I have to do a custom chassis order for this PT? Thanks.
Mercury Magnetic JTM45-RI-P won’t fit.... Help.
Can you just drill new holes? The transformer is upright or the laydown style?
https://reverb.com/item/13212544-mar...w-iec-knockout
this person can make a custom chassis for you but not sure if you need it all predrilled and pre cut
re-issue transformers are not always the same size as the originals. I suppose the metro is using the original size PT.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
But, whatever else Mercury does, they usually clone accurate for mounting from what I've read. So the RI must use a different size transformer than an original, which is likely what the Metro chassis is cut for.
It's a clone, not an original. Even boutiquey type amps often have odd cutouts and plugs for correction. Drill new holes or, if necessary, add a mounting plate or something. I don't think it's great shakes unless you're OCD over it.?."Take two placebos, works twice as well." Enzo
Some info anyway. Didn't think they had these all online.
http://mercurymagnetics.com/images/p...JTM45-RI-P.pdfThe only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Thanks to everyone. I will post some pictures when I get to my desktop computer. iOS forum doesn’t have an option to upload images. Transformer is a tad too small, so drilling new holes in not an option. I’ll probably re-use this chassis for a proper sized PT. In the meantime I’m going to call MM to ask what they where thinking when they made this particular model.
Originally posted by cluster View PostIn the meantime I’m going to call MM to ask what they where thinking when they made this particular model.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
This^^^^^^^^^^^^^^^^
Why make enemies when you may be in the wrong.?."Take two placebos, works twice as well." Enzo
I'm finding it hard to believe that you couldn't make it work. Maybe some drilling, maybe a trip to the hardware store for washers, etc. Looking at your numbers in the first post and the datasheet Mike so graciously posted, the transformer should cover the holes in the chassis. Nobody would see any "adapting" you'd have to do internally in order to securely mount it."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Round into the corners of the cutout and use an unsecured adapter plate inside. Sort of sandwich the chassis between the transformer and the plate. You'll need to make the plate, of course. Shouldn't be too hard if you have the tools."Take two placebos, works twice as well." Enzo
