Originally posted by nevetslab
View Post
Fender Bassman 100 Head Silverface 1974 - Blows Fuse
Originally posted by misterc57 View PostIs the current handling added when they are in series? So (3) at 2 amp are now rated at 6 amps?Building a better world (one tube amp at a time)
Getting my parts list together. I will be replacing the 6L6 resistors and the bias and filter circuit resistors. Does it matter if they are carbon film versus metal film? Is there a preference? I would think that all the original are carbon film.
Thank you
It is easy to check resistors.
While it may be a good idea to get some spare parts (especially tubes), I am not in favour of blindly replacing working components. Such action always bears the risk of unconsciously/accidentally producing new problems.
I have some Fender amps from the 60s and 70s that work just fine with original caps and resistors.
Original resistors are carbon compound not carbon film.- Own Opinions Only -
While it may be a good idea to get some spare parts (especially tubes), I am not in favour of blindly replacing working components. Such action bears the risk of unconsciously producing new problems.
Originally posted by misterc57 View PostWell that is food for thought. The only thing bad that I know of are those rectifier diodes. All the filter caps tested good but are original 44 year old caps.- Own Opinions Only -
If they are 44 year-old filter caps, I vote for replacing them. It's better to replace vintage filter caps than finding yourself having to replace those vintage transformersBuilding a better world (one tube amp at a time)
If the amp shows correct voltages and doesn't hum excessively after repair there is no need to replace caps.- Own Opinions Only -
Originally posted by tubeswell View PostIf they are 44 year-old filter caps, I vote for replacing them. It's better to replace vintage filter caps than finding yourself having to replace those vintage transformers
Originally posted by HelmholtzI never found a shorted e-cap.This isn't the future I signed up for.
I agree with Helmholtz and Leo_Gnardo.
I've never found a shorted vintage e-cap. But I have seen shorts in newer manufactures.
I won't weigh in on whether you should just replace them or not, (that's an argument that goes for pages every time it crops up ), but I do agree you should always fix the problem first, perform upgrades later.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I found a several shorted caps on a Tonemaster last year - 'it keeps on blowing fuses' the guy said. And after they were replaced the thing worked again.
I had a 67 Super reverb come in a couple of months ago with a blown OT and a shorted bias supply cap. 2 of the filter caps were bulging as well, so I changed them. Customer was happy to have his amp working again
I had a 73 Vibrasonic Reverb humming like crazy last month with a dead smoothing cap. Another cap job. I replaced the old white mallory bias supply cap just in case. (Only took a couple of minutes) Amp sounded all better afterwards.Building a better world (one tube amp at a time)
I wasn't aware of e-caps eventully shorting. Might be a good reason for adding a B+ fuse as the failure doesn't seem to be predictable. If even new caps may fail after only 2 years I prefer to stay with the old ones as long as they measure O.K. and show no signs of physical leakage - at least in my own amps.
In my former company we continuously tested hundreds of e-caps of several brands for over 50,000 operating hours at 85°C. They were measured before and after testing. Never heard of a shorted one. But we only used SMPS grade 105°C types.Last edited by Helmholtz; 09-04-2018, 08:24 PM.- Own Opinions Only -
