It depends on how jiggy you want to get with it. I've fixed such things when there was a layer wrap between the winding connection for the lead wire and I was able to actually find it. The only motivation is that NEW TANKS SUCK! Not even trying to be subtle here.
1978 Fender Super Reverb UL -- WEAK REVERB HELP!
Looks like you can still see a bit of the green wire at the coil? If so it's worth a try. You can carefully undo that tape around the coil and see if you can get on the wire stub.
Like Chuck said, if this is an original tank, it's worth fixing. The new ones are not the same.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
That's the nub g1 was talking about. I don't know the mechanical reason why, but there always seems to be a nub. Keep unwrapping. There's more in there. If you can expose enough to lift the lead from the bobbin try to strip and expose a millimeter or so (I've used a razor knife because you can't get a pair of strippers in there). Slip some doubled over aluminum foil under the wire to protect the bobbin and coil so you can solder another lead wire to the nub.
And FWIW I've only attempted this twice and it only worked once. The second time there was too much oxide on the wire strands in the nub and they just wouldn't take solder well enough. Trying to take the repair further destroyed the coil."Take two placebos, works twice as well." Enzo
As said replace all those electrolytic caps. Not just the one under the doghouse, but all the 25/25V's on the board. The only one I'd consider leaving is the 5/50V off V5B as I've never managed to find a close enough match and it has quite an effect on the trem.
And DON'T FORGET THE BIAS SUPPLY CAPS!
Yes, I'm shouting.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
