Sunn(0))) Amp Beta Bass Repair
That's 60V peak to peak signal voltage. If you are set up however they instruct for the AC signal test, and your TP1,2,&3 are correct (AC p-p), then no, 18V p-p at TP4 is not normal.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by wirelessliquid View PostIgnor my last post I figurered that out haha, test leads the wrong way round
Tested the circuit and I'm getting the correct + and _ 15V out on the rights pins,
Tests points 1, 2, 3 look good but TP4 is 18V rather than 60V is this normal.
[ATTACH=CONFIG]50588[/ATTACH]
You would NOT be able to get the 60V P-P at this point, since we're NOT yet connected to the brute-force power supply of the product. Remember?
The output at the zobel network L1 & R52 might show oscillation, since we're not pulling base current from Q7/Q16 that drive the output stage. But, you should be able to get full voltage swing. With +/- 30VDC supplies, I'd guess you might swing 40-45V p-p at TP4.Logic is an organized way of going wrong with confidence
Originally posted by wirelessliquid View PostI'll check that tonight
I thought this would be the case
What do you mean by a voltage swing?Logic is an organized way of going wrong with confidence
Originally posted by wirelessliquid View PostOn the base of Q7 & Q16 I'm seeing 18VDC & -18VDC
Vbe looks to be about 0.5V
I have installed the output stage at this point and it looks okay, I'm still seeing the 18Vp-p rather than 60Vp-p
I would disconnect the output stage until you have the bias circuit working. With the trim pot R42, you should be able to pull the bases of Q7/Q16 down to maybe +/- 1V or less, and on the high side, run them up to maybe +/- 2.5V.Logic is an organized way of going wrong with confidence
Originally posted by wirelessliquid View PostThe pre amp is pulling around 4mA on -15V and about 50mA on +15VLogic is an organized way of going wrong with confidence
Originally posted by wirelessliquid View PostI should note the schematic is from a Alpha series amplifier where this is a Beta amplifier, the power board is almost the same though, F2 & F3 are 6A on my amplifier where as they are 10A on the schematic, for 100W output is around 18V * 6A could this be that 18V?
Typically for a 100W amp, you'd need about +/- 50VDC. Under full power, the supply sags, dropping down to maybe +/- 45VDC or less. So, your amp is maybe rated 50-60W output.Logic is an organized way of going wrong with confidence
Should I just turn R42 until this trims Q13 properly then? the bias in the service manual states that I should see 1MV over R18 after 10 seconds of power. I'm also having trouble with some of the pads lifting up now as I've soldered components in and out so many times. The output stage was never turned on hard, the output transistors didnt' heat up at all, no smoke either
With the output stage disconnected how can I test on the test points as the reading will not be the same?
that's a typo there 40mV and 50mV sorry, on the power board when I add the Op amp IC it increases the current draw on either side by +20mV and +40mV,this should also have an equal increase in current draw
The output for this amplifier is to a 4Ohm load, says 4ohm 100W output on it
I removed the output stage to check it still worked and checked the semi conductors and all appears to be okay so I put the output stage back in to do a test to see if it was the Q13 trim on R42. trying to get the base of Q16 down to -1.8V creates massive current draw which trips the current protection on my power supply, the amp will only sit stable on the power supply with the basse of Q16 at -18V.
I took reading of all the test points on the circuit and what they should be on the schematic if this help at all.
Actual Voltage
tp 1 = 0.8VDC
tp 2 = 6.4VDC
tp 3 = 10.07VDC
tp 4 = -15.98VDC
tp 5 = -18.54VDC
tp6 = -17.21V
Schematic Voltage
tp1 = 2.2V p-p
tp2 = 0.7V p-p
tp3 = 0.9V p-p
tp4 = 60v p-p
tp5 = 60v p-p
tp6 = 60v p-p
these are both vastly different which is confucing me as all semi conductors are working and I can't find any shorts
Originally posted by wirelessliquid View PostShould I just turn R42 until this trims Q13 properly then? the bias in the service manual states that I should see 1MV over R18 after 10 seconds of power. I'm also having trouble with some of the pads lifting up now as I've soldered components in and out so many times. The output stage was never turned on hard, the output transistors didnt' heat up at all, no smoke either
Does your schematic show DC voltages on components thruout the schematic? On mine, for instance, it shows -1.7VDC on the collector of Q14, which is the base of Q16. It also shows 1.2VDC on base of Q8/Emitter of Q7, and -1.2VDC on base of Q17/emitter of Q16. Those are your target voltages, which in adjusting the bias pot R42 should achieve. With regards to the 1mV across R18, that sounds typical. I've always been adjusting by watching the voltage of the emitter on the previous stage.......that across R17 & R47, where a typical bias voltage would be between 375mV and 450mV. Another means of adjusting bias is to watch the mains current of the amp being adjusted, and set it to where the mains current just begins to increase. You could do similar, watching the current readings on your lab supply as you adjust R42. I'd monitor both the voltage on either/both R17 & R47 while watching for current increase. This adjustment controls the crossover distortion, setting the output stage bases close to but not at the point of where they turn on and begin conducting current.
100W @ 4 ohms is 20V RMS, same as 50W @ 8 ohms.
Sorry about the solder pad lifting issues. All of us go thru that horror, and seek ways to combat it during service. That aspect is a real PITA, worse on some gear than others due to the quality of the PCB. I've often had to resort to using short EZ-Hook cables to clip parts in and out to avoid the constant heating of the solder pads until the solution is at hand.Logic is an organized way of going wrong with confidence
Originally posted by wirelessliquid View PostI removed the output stage to check it still worked and checked the semi conductors and all appears to be okay so I put the output stage back in to do a test to see if it was the Q13 trim on R42. trying to get the base of Q16 down to -1.8V creates massive current draw which trips the current protection on my power supply, the amp will only sit stable on the power supply with the basse of Q16 at -18V.
Actual Voltage
tp 1 = 0.8VDC
tp 2 = 6.4VDC
tp 3 = 10.07VDC
tp 4 = -15.98VDC
tp 5 = -18.54VDC
tp6 = -17.21V
Schematic Voltage
tp1 = 2.2V p-p
tp2 = 0.7V p-p
tp3 = 0.9V p-p
tp4 = 60v p-p
tp5 = 60v p-p
tp6 = 60v p-p
With TP 1 (base of input xstr Q1) at 0.8V, I'm wondering if that's a result of IC1B trying to compensate the negative output voltage at TP6. I'd lift R22 out of circuit, or, if IC1 is on a socket, remove it.
With the output TP6 at -17.2VDC, seeing TP5 at -18.54V is good, as that tells you Q17 & Q16 are ok.
Looking at the voltages stated on the schematic, it shows 500mV across the emitter resistor R38 of Q14, which is 3.3mA. You should have that same voltage across Q5's emitter resistor R13. All the essential DC voltages are shown on the schematic to guide you, though I certainly understand the frustration level when so many aren't in agreement. That's part of the learning curve in understanding how these things work. With feedback in the system where a circuit isn't working, I've had to open the loop and make connections to force DC stability to find the parts that aren't working, even when my DMM is telling me parts suspect show good semiconductor junctions. We haven't gone there yet, but you're getting close. Remember, we're still trying to recover from having the supply voltages reversed. You're making progress.Last edited by nevetslab; 10-07-2018, 05:11 PM.Logic is an organized way of going wrong with confidence
