Page 1 of 2 12 LastLast
Results 1 to 35 of 36
Thread: Drumming with MIDI
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Drumming with MIDI
    Thanks to this forum, I got big props from my daughter for sorting out her missing amp. Little did she know that I'm just trying to keep from going broke supporting her art. I got an old computer set up with an internal sound card. From what I've been told, the sound card is DMA capable and plays MIDI so it will have low latency. I don't know exactly what this means but I think it's good. On the computer, the sound card has a MIDI port. Is this port both an input and an output?
    I need to know this because the "right" cable is $50 and has both standard MIDI ins and outs with a 15pin computer MIDI. I don't want to waste money on something that won't work but the huge library of MIDI drum patterns and the ease of working with them makes this look like the way to go. For the same $50, I could probably pick up an SDRUM or similar drum beat maker and lose the computer. Which is the best way to get decent drums without a drummer?
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    MIDI or Musical Instrument Digital Interface is a control method. It deals with control information and not the actual signal itself. MIDI is not normally bi-directional. A MIDI jack will normally be an input or an output and not both. There is often also a "thru" for routing to multiple devices. MIDI control will control note information, patch changes, etc. I'm not exactly sure by your question what your intent is. If you could more specifically explain what it is you're after, it might be easier to give you answers. If she just wants to practice with drums, the cheapest/easiest option might be to run the computer as a drum machine using it's own speakers and the guitar rig separately.
    Site Janitor tboy's Avatar
    Behind The Zion Curtain
    630
    Blog Entries
    1
    Received: 321/1
    Given: 229/4
    14
    The 15-pin "game port" on an old sound card does carry both MIDI in and out, but Windows support for that port ended with Vista, and $50 is much more than you should have to spend for the MIDI breakout cable. If all you want to do though, is to play MIDI drum patterns on the computer, you don't need a MIDI interface at all unless you have some kind of external MIDI synth or sound module that you intend to use to produce the drum sounds.
    3 Not allowed! Not allowed!
    -tb
    Supporting Member John_H's Avatar
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    Before spending so much for an obsolete connector, You should consider looking for a used small control surface that interfaces with USB. I see them selling frequently for about the same price as your cable.
    Here's an online drum machine that You can program DIY.
    https://drumbit.app/
    PS- Do a search for free sequencers.
    5 Not allowed! Not allowed!
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    Oh! That's quick and easy, John. I hadn't seen that before. Thanks for the link!
    1 Not allowed! Not allowed!
    Sep 2011
    Pace, FL
    2,730
    Received: 761/100
    Given: 110/33
    10
    i used to get the old rockband drumset and set it up with a computer and the kids would play on it.https://www.wikihow.com/Play-Rock-Band-Drums-on-Your-PC
    nosaj
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Quote Originally Posted by tboy
    I think Windows 7 still supports the interface in “Compatibility Mode” but Linux is also an option. The way she explained it to me; she will play her strings and sing into the GSP21 which will output MIDI to the computer where she will first store, then compose all the parts. Then she will render the mp3s from the MIDIs and record them.
    Quote Originally Posted by John_H
    Research indicates you need a USB 3.0 port and a current computer to get lower latency than an internal card with DMA. That makes the cost much higher than just the interface for equivalent performance. Thanks for the great link.
    Quote Originally Posted by nosaj
    Oh no, not another instrument! Even the SDRUM would be a better option than that.
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    Quote Originally Posted by syzygyn View Post
    ......The way she explained it to me; she will play her strings and sing into the GSP21 which will output MIDI to the computer where she will first store, then compose all the parts. Then she will render the mp3s from the MIDIs and record them......
    If I understand your "flow chart", that won't work. MIDI in/out of the GSP21 (as far as I know) is for program changes, etc. You won't get audio from any MIDI jack. There are some older samplers that do send audio files via MIDI when you do a MIDI sample dump, but that it not MIDI's normal configuration and there isn't audio stored in the GSP21 to dump as far as I know. You'll instead need to send analog audio into the computer's sound card and record it with a program that does multi-tracking to achieve what you're looking for. There is a freeware multi-tracking program called Audacity built for this if you're interested in checking it out. There are many others, but this one is freeware and works pretty well, IMO.
    https://www.audacityteam.org/
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,478
    Received: 1,381/7
    53
    MIDI is all digital code. No audio. It tells a sound generator to play whatever notes are assigned. If I plug my MIDI controller into a piano sound module, I get piano sounds. If I plug the exact same MIDI signal into a drum module, I get drum sounds.
    630
    Blog Entries
    1
    Received: 321/1
    Given: 229/4
    14
    I think you're confusing MIDI latency here with digital audio latency. Even USB 1 has far more speed than is needed for MIDI data.
    -tb
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    I might be confused but if I'm recording and editing in MIDI, there has to be a digital to analog conversion. If the D/A conversion is handled inside the computer box then the latency matters but I don't really know. MIDI is really efficient and small but it can pack lots of information when all its commands are fully supported. Unless I'm misunderstanding what I'm reading, the Digitech processor MIDI is fully implemented and not just a control I/O. If you look in the manual, all the sound parameters have hexidecimal equivalents. From what I've read, the GSP21 will deliver everything about its sound over MIDI when the input is guitar so why wouldn't it be able to do the same thing with a bass or a voice input?
  12. #12
    31,478
    Received: 1,381/7
    53
    The best analogy I have is MIDI is like the rolls of paper on a player piano. If I invent a player tuba and stick the piano roll into it, it will play the tuba. MIDI is completely digital, it does not send audio. When you have a MIDI keyboard or other controller and press a key, MIDI then transmits: a "note on" signal, the particular note, or really the note number, the velocity. The note itself is not sent, just the instruction to play some note number when it gets to a sound module. And that note over there will continue to sound until a "note off" signal is sent. In other words, if I press a key to get the sound, then as I hold the key down, I unplug the MIDI cord, then at the sound module, it continues to sound even as I release the key. Because the sound module never saw a note off signal.
    MIDI is a communication protocol between units.
    If I record a MIDI stream, I can play it back through any MIDI device. I may play on a MIDI piano, and it comes out as piano through a MIDI sound box. But if I play the same MIDI stream into a drum box, it comes out as drum hits. Think of it as sheet music rather than tape recordings.
  13. #13
    Dec 2008
    Wernersville, PA
    12,665
    Received: 341/2
    Given: 176/0
    25
    "If I invent a player tuba"
    You may be on to something there Enzo.
  14. #14
    31,478
    Received: 1,381/7
    53
    (Aside)
    My wife gives out rubber duckies everywhere she goes. Mainly to little kids, and always through their parent. One practical advantage to this is the kid then has a toy and we get a more peaceful meal in a restaurant. But some kids get a rubber duck and they sit there bouncing the duck on the table repeating "duck, duck, duck, duck,..." for a half hour. We snicker. The parents actually 99.9% of the time appreciate the gift, but sometimes the kid chanting "duck" gets old. I often tell them as they pass by, "Hey, we used to hand out tubas."
  15. #15
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    What software are you using for recording, and editing? If you're recording guitar somewhere along the signal chain there has to be a A/D converter with an interface to your computer. From there the converted audio can be input into a Digital Audio Workshop, or DAW. The same goes for recording vocals. Neither of these can be converted to midi. However that same DAW can record a midi track that has been processed through a software synthesizer as an audio track into your mix. This can be anything. Whatever instrument/sound you want... I'm not sure where the midi function fits in on the digitech GSP21. GSP stands for guitar signal processor I think. Perhaps you can plug a keyboard into it, or patch a midi track in, and that it acts as a guitar synth that you can plug into an amp while utilizing all of the features of the multi effects board. I'll look for a manual and d/l it.
    Check out this BB It's a great place to start. They treat noob's nicely. http://homerecording.com/bbs/
    2 Not allowed! Not allowed!
  16. #16
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    MIDI is more than just sheet music. The amplitude and dynamic qualities of the music can be precisely defined along with its timbral qualities. We haven't decided yet on the software but I'm experimenting with Linux (Audacity, Timidity, etc.). I found the manual in the link below:
    http://www.tube-tester.com/sites/gsp...p21-legend.pdf
    Thanks again for your link. It looks like I was wrong about the GSP21 being a fully implemented MIDI. It doesn't have the necessary encoding parameters for any input. Does anyone know of a processor that can do what she wants to do?
  17. #17
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    I use REAPER. It's free to try. https://www.reaper.fm/download.php
    Did you check out the home recording forum?
    ...The amplitude and dynamic qualities of the music can be precisely defined along with its timbral qualities.
    Yes Absolutely.
  18. #18
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Yes, I've been on the homerecording site. I'm hearing lots of good things about Reaper but its hard to beat the cost of Audacity. It seems like a pretty competent tool. What will I miss not having Reaper?
  19. #19
    630
    Blog Entries
    1
    Received: 321/1
    Given: 229/4
    14
    MIDI is more than just sheet music. The amplitude and dynamic qualities of the music can be precisely defined along with its timbrel qualities.
    MIDI actually is a lot like an electronic form of sheet music. It might be a bit more "precise" in conveying the exact parameters of a particular musical performance, but I wouldn't cut written music short in it's ability to communicate "the amplitude and dynamic qualities of the music" - it just does it in a different way.
    If you're willing to explore the capabilities of Linux for music/audio production, there's a lot of really good software out there now. and even some entire distributions that are packaged specifically for the purpose. You might even find something that can do a fairly good conversion of singing into MIDI data.
    -tb
  20. #20
    31,478
    Received: 1,381/7
    53
    yes, of course it is, but I was trying to draw the distinction between MIDI and audio. As precise as it may be, there is zero audio in the MIDI signal. I seemed to me there might be some confusion about that. I could be wrong.
  21. #21
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    This thread made me think of this song. It helps that I'm a timbuk 3 fan.
    ...If you're willing to explore the capabilities of Linux for music/audio production, there's a lot of really good software out there now.
    I noticed that there was a Linux beta version of reaper when I went after the link.
    ...What will I miss not having Reaper?
    I really don't know. I tried a couple of others before it, but it's all I've used for about 15 years. I'm not very good at this, but hanging out at the HR forums really upped my game.
    My daughter's boyfriend owns an well established studio here in Vegas. He's an incredible engineer, and a mastering wizard. http://www.digitalinsightrecording.com/ He really needs to update his website. They just completely remodeled the 'B' room.
  22. #22
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Quote Originally Posted by Enzo
    I understand you now, sorry. Too many people still think MIDI is just a command and control thing. They don't realize how close to music it really is. Ideally, my daughter wants a processor pre-amp that can take an input signal (voice, bass and guitar) add effects to it and send that MIDI to her computer. This means the processor pre-amp has to be able to completely encode the processed signal to MIDI by itself. I thought the GSP21 could do this, it can't. Is there any processor pre-amp that can?
  23. #23
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    ...Ideally, my daughter wants a processor pre-amp that can take an input signal (voice, bass and guitar) add effects to it and send that MIDI to her computer. This means the processor pre-amp has to be able to completely encode the processed signal to MIDI by itself. I thought the GSP21 could do this, it can't. Is there any processor pre-amp that can?
    Nope. It has to be a combination of tools. tboy says that there are all-in-one packages, but they're only "fairly good".
  24. #24
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    I'm not sure why you're insisting on doing this. MIDI was never intended for audio transmission. It's a control format. Just put the sounds in the computer via the sound card analog input and record them. That will convert the sounds to a digital format. Do all the editing in software. You can add your effects there and do multiple other things to the waveforms and mix the different instruments. If your existing sound card doesn't have all the inputs and outputs you need, get something like this:
    BEHRINGER Audio Interface 1x XLR/TRS 1x 1/4" 2X RCA USB, Black 1-Channel UM2
    There are tons of others. I linked that one because it's a low cost option. I'm not endorsing any particular brand or model.
  25. #25
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 263/0
    Given: 255/0
    14
    I've got these. Nothing special. The best feature IMO is that you can monitor with zero latency through the headphone jack on the unit. https://www.alesis.com/products/view/m1active-320-usb
  26. #26
    630
    Blog Entries
    1
    Received: 321/1
    Given: 229/4
    14
    I don't really want to sound the back-skipping record on your turntable, but MIDI really is "just a command and control thing."
    -tb
  27. #27
    Aug 2012
    Great Black Swamp
    2,106
    Received: 311/0
    Given: 768/1
    9
    As far as Guitar-to-MIDI for note sequencing, Roland had it in the bag for many years. Graphtech also has a converter too, I think. None of this is A/D conversion, it is like as was said, a "piano roll" abstraction of the guitar notes. More sophisticated converters can capture pitch bend, etc., and send it out as a continuous controller. It's been many years since I sat down with a MIDI-equipped guitar, and don't know how much the tech has progressed since. Check out Roland's guitar-to-MIDI pickup. This could feed the signal into the PC (the piano roll making machine) for later editing and playback. If your daughter is not interested in real-time virtual instrument performance - where latency becomes an issue - then the Roland, or any other, guitar MIDI pickup would work stand alone feeding the PC.
  28. #28
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Perhaps my assessment of MIDI was a bit optimistic. I thought the entire waveform could be encoded into that command and control language. It may be in our future but it doesn't look like it's here yet. I suppose the next closest thing is a digital capture with a MIDI drum overlay. The guitar MIDI converters seem pretty good but they are too specific and expensive for what we were planning. You would need one for voice and bass too. Thanks all for your guidance.
  29. #29
    31,478
    Received: 1,381/7
    53
    Look up the ABCs of MIDI. I may be wrong, but I think you have in mind it is a digital recording platform, when it is not.It really is like a player piano roll or a sheet music in that all it contains is what note to play, how loud to play it, when to let go of the note, and other things like patch change commands. Nowhere in it is the sound that is to come out. That is up to the sound module receiving the MIDI. I might have a piano voiced sound module, and notes 1 through 8 are assigned to the scale from C1. SO on any MIDI controller if I play note 1 on the keyboard, note 1 from the sound module plays, in this case C1. Note 2 D1 and so on. But if I plug the exact same MIDI signal into a drum module it plays notes 1, 2, 3, etc, but in that case note 1 might be the snare, note 2 a floor tom, note 3 a hi hat...
    Of all the stuff, the actual sound is not encoded in the MIDI stream. The sound you hear is totally determined by the sound module the MIDI signal controls.
    Keyboards tend to have key numbers assigned similarly, so my Casio MIDI controller/synth will play the same notes of the scale when I am MIDI'd to a Yamaha synth or a Korg. But I can easily reprogram my MIDI stuff to transpose or partition my keys to play other things.
    There are plenty of "MIDI controllers" which are keyboards that have no sound generation at all, they are strictly a MIDI controller. Like the venerable Yamaha KX88.
  30. #30
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    Sorry. You're not listening. MIDI is a control language. Even the guitar MIDI converters do not sample the guitar and output audio. They take guitar note information and convert it to note control for controlling keyboard sounds, etc. Even if you had one, you wouldn't get the original guitar sound out of it.
    "It may be in our future but it doesn't look like it's here yet."
    Nope. It's not in the future. There are actual tools readily available for sampling audio. MIDI is not one of those tools. You are trying to make coffee with a toaster.
  31. #31
    Dec 2008
    Wernersville, PA
    12,665
    Received: 341/2
    Given: 176/0
    25
    "I thought the entire waveform could be encoded into that command and control language".
    Audio can be converted to MIDI.
    Where you really hit the snags is when you expect the conversion to be perfect.
    Imagine trying to convert a full symphony to MIDI.
    Yes it can be done.
    But you will 'lose' an awful lot of the information.
  32. #32
    May 2010
    Sioux Falls, SD
    5,781
    Received: 769/1
    Given: 629/1
    14
    Quote Originally Posted by Jazz P Bass View Post
    ......Audio can be converted to MIDI......
    For clarification. Audio itself is not converted to MIDI. Note #, Note On, Note Off, etc. information is converted to MIDI information. The audio is not sampled.
    For instance, let's say I play a 'C' note on guitar into a MIDI converter. MIDI knows that I played a 'C'. It knows when I started to play the note and when I stopped. It may also know the velocity or how hard I played the note (depending on the converter). It has no idea what the sound is. It could have been a piano, tuba (thanks Enzo), guitar, voice, or anything else. There is no way for MIDI to recreate exactly the sound played into the converter. The recreated sound is determined by the device triggered by that MIDI information.
  33. #33
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Gentlemen, MIDI is only a descriptor of the music. We all agree on this. The difference is in how detailed the descriptor result is. Anyone that has been in the graphic arts field understands a postscript file is a descriptor of the image. In its earliest incarnations, it was unable to describe real life images and shading. As it evolved, those capabilities came. I see MIDI the same way. I think Jazz P Bass has the clearest picture of MIDI in its current state. I'll continue to watch this thread but I won't post unless someone posts something to change that opinion. Thanks to all for the help.
  34. #34
    Sep 2011
    Pace, FL
    2,730
    Received: 761/100
    Given: 110/33
    10
    Does this have anything to contribute to the conversation?
    https://hackaday.com/2018/10/30/wave...-for-everyone/
    nosaj
  35. #35
    Banned
    Aug 2018
    85
    Received: 26/7
    Given: 62/27
    0
    Thanks for the input but this only looks like an Aduino/Raspberry sound card. It doesn't do the MIDI transcription I was looking for as far as I can tell. For that you need dedicated computer software. So far, the results don't work well for complex arrangements.
  1. MIDI In with a 6N138
    By Wilder Amplification in forum Music Electronics
    Last Post: 02-21-2016, 12:47 AM
  2. Peavey 8 Pin MIDI
    By The Dude in forum Schematic Requests
    Last Post: 03-29-2013, 04:49 AM
  3. Analog to midi
    By intarsiaq4 in forum Music Electronics
    Last Post: 01-27-2010, 06:09 AM
  4. 7 pin midi
    By tsmilliner in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-02-2009, 10:24 PM
  5. midi questions
    By Marina in forum Music Electronics
    Last Post: 12-26-2008, 03:16 AM
