Results 1 to 4 of 4
Thread: Multivox Premier 120 Tremolo
    Dec 2008
    785
    Received: 21/1
    Given: 4/0
    11
    I've worked on a couple of Premier 120 amps and have one in the shop right now. It's from ~1954, the version with 12AX7s rather than 6SL7s.
    I saw a video online where someone was adjusting the tremolo speed on a Premier 120 in the same cabinet, but this amp I'm looking at only has a rotary tremolo on-off switch on the main control panel with no speed control.
    Does anyone know much about the evolution of the 120 and its features?
    Oct 2015
    NEPA
    767
    Received: 149/1
    Given: 109/0
    4
    I have one of these, but have to dig it out. Premier's can have any number of schematics for the same model number. Pretty sure mine has the 12ax7's and a fairly long tag board inside.
    Oct 2015
    NEPA
    767
    Received: 149/1
    Given: 109/0
    4
    Ok, mine has what you call a TV front. 4-12ax7's (one may be a 12at7, telefunkens, printing is gone) 2-6v6 and 5y3. Serial # is 214xxx. Gold Jensen speaker dated 1962 , syntox-6 c12rc which i am 50% sure is not original so without pulling it apart i can't say what year the amp was made. Tremolo has 2 controls, one labeled "-->IN" and the other labeled "-->FAST", so i take that as depth and speed. No tremolo on-off on pots, just a tremolo footswitch jack on top next to the pots.
    Let me dig through my schematics, my other model Premier B160 i have found 3 or 4 different ones. By the way, these cabinets are particle board junk. Last one i moved to a tweed deluxe cabinet, took 4 mounting screws instead of 2, otherwise it was almost a exact fit. This model 120 has 4 input jacks just like a tweed deluxe and i suspect the dimensions are very close once again.
    I am seeing all different cabinets, all called MODEL 120. TV front with raised upper portion. 4 knobs, TV front with regular cabinet, other ones have chassis on the bottom.
    Dec 2008
    785
    Received: 21/1
    Given: 4/0
    11
    Multivox churned out a bunch of different versions of the 120.
    It's common to have a 12AX7 V1, grid-leak biased. V2 and V3 are a 12AX7 and 12AT7 that work together as the tremolo circuit. V4 is a 12AX7 phase inverter driving a pair of 6V6s with a 5Y3 rectifier.
    Likely original 12" speaker is a "Best" brand speaker dated 1951.
    There was another presumably earlier version that used 2 6SL7s and 1 6SC7 instead of three 12AX7s.
  1. Multivox Premier 120 combo w/tremolo
    By davohilts in forum Vintage Amps
    Last Post: 11-12-2015, 09:24 PM
  2. Tremolo pumping the speaker in Premier 120
    By Rhodesplyr in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-26-2013, 08:38 PM
  3. Fun with the Multivox Premier 120
    By Rhodesplyr in forum Vintage Amps
    Last Post: 01-21-2012, 06:35 PM
  4. Multivox Premier 120
    By Rhodesplyr in forum Guitar Amps
    Last Post: 01-28-2011, 07:07 AM
  5. Help with Multivox Premier 71
    By tonydj in forum Vintage Amps
    Last Post: 05-06-2009, 07:44 PM
