need Sampson SS schem.
  • need Sampson SS schem.
    I have a Sampson C700 power amp that someone already tried "fixing".
    They cut the leads to all the shorted output devices.
    Anyone have or know where to get a schematic for one of these before I see if it's worth fixing?
    Thanks all.
    C700? I don't know that one, and it is not in my files.
    Did you contact Samson and ask for the drawings?
      my bad...S700
      didn't try Sampson yet, do they release schems?
      I'll try them tomorrow.
      You have a contact #?
      thanks mon.
        I am sure the phone number is on their web site. Try them first. I have the S700, but I'd have to do a clumsy multiscan.
          by-the-by I had one of these in a few weeks ago. They have cut things maybe a bit fine on the filter caps to get them close to the board and keep the amp thin; one of these had shorted and fuses were blowing. I forget the voltage ratings but there was not much margin and they were 85-degree caps also in what is a potentially hot situation I guess. If you get it wired up again you might check the caps - with the fuse blowing it might have looked to someone like a power device failure I guess.
