Peavey Transtube 112 EFX: No Output and DC on the Speaker Leads
  • Peavey Transtube 112 EFX: No Output and DC on the Speaker Leads
    I am working on a Peavey Transtube 112 EFX. It came to me with "a loud hum" but no output.
    (I am trying to add as attachments a schematic of the power amp for this amp and a drawing of the pinout for the LM3886, but the files simply will not upload. I'll continue working on it and add them when I can.)
    I disconnected the speaker, checked for DC on the speaker leads and measured -39vdc with my red voltmeter probe on the wire that connects to the positive speaker terminal and my black probe on the wire that connects to the negative speaker terminal.
    I isolated the problem to the power amp by running the a cable out of the effects send to the power amp in of a known good amp and confirming that everything worked as it should.
    This amp uses an LM3886 Audio Power Amplifier for its output.
    I traced a signal through the power amp to pin 10 of the LM3886. From there, there is no signal out of the LM3886. I measured voltage on the various pins and got the following readings"
    Pin 01: 39.3vdc
    Pin 02: 0.00
    Pin 03: 39.3vdc
    Pin 04: -39.5vdc
    Pin 05: 39.2vdc
    Pin 06: 0.00
    Pin 07: 0.00
    Pin 08: -1.2vdc
    Pin 09: -2.0vdc
    Pin 10: 0.00
    Looking at the power supply, I measured + and - 15vdc where the schematic shows it, and + and - 39vdc where the schematic shows + and - 35 volts.
    I did not find any obvious damage or failed components, although C119 had a cracked solder joint, which I repaired.
    I am looking for suggestions as to where to look next. The voltage measurements on Pins 3, 8, and 9 of the LM3886 look fishy. Does it look like the LM3886 may be bad? How would I test that device?
    Does anyone have other suggestions as to what might be wrong here?
    Thanks.
    If you have a rail voltage at the output of the LM3886 (pin 3) and +&- supply are correct, you almost certainly have a shorted IC. Try a new one.
      Beat me to it. A chip amp like LM3886 with DC on the output is almost always just a bad IC.
        Thanks, The Dude and Enzo. I will replace it and report back.
          It occurred to me to ask. . . I have 39vdc where the schematic shows 35vdc. Is that "close enough" or should I be concerned?
            Close enough.
              Thanks, Enzo.
                To close the loop. . . . I replaced the LM3886 and that fixed the problem. The amp now works as it should. Thanks for your help.
                John
                  I'm having the same problem with my Peavey 112 efx transtube. I'm looking for either a service manual or schematic, parts list and circuit board layout!
                  Does anyone know where I can obtain this?
                    Have you contacted Peavey? It's been over a decade since I contacted them for information but at that time they were very receptive and helpful. More recent reports from other members here indicate this hasn't changed.
                    https://peavey.com/c/Contact-Us
                      Well perhaps the 212 EFX transtube is close enough?
                      PV TRANSTUBE_212_EFX.pdf
                      TRANSTUBE_212_EFX_pa.pdf
                        Thanks Doc, that enabled me to find my 112 schem.
                        attached
