Problems with uploading attachments
  • Problems with uploading attachments
    Do anyone else having problems with uploading files from computer to music-electronics-forum.com?
    After Go Advanced/ Manage Attachments/ Add Files/ File upload, attachments does not load.
    Is anything wrong with the procedure, or is there anything else to do?
    Thanks for any help.
    vk
    It's All Over Now
    I'll try it.
    Upload test.zip
    It worked. I'm using Pale Moon browser.
    Last edited by Boss; 09-19-2018, 10:26 PM. Reason: fixed broken color tag in quote
      test
      OK I upload your Upload test.zip It works
      But I can not upload your file (Upload test.jpg) from your test.zip file
      I tried, still I can not upload any my files (.zip .pdf)
      What is magic?
      It's All Over Now
        Changing name to "upload test a.jpg" for a test:
Name:	Upload test a.jpg
          OK I upload a.jpg It works
          I tried, still I can not upload any files from computer (.zip .pdf)
          By now I upload 180 files
          Maybe somewhere I'm wrong?
          It's All Over Now
            I tried a test (from IE) and .jpeg & .gif upload o/k.
            .bmp and .pdf do not upload.
            (not loading a .pdf is a killer!)
            Also, if I choose the 'insert image' icon, the .pdf will not upload.
            (This is how I usually upload a file)
              It was done as it is written.
              https://music-electronics-forum.com/showthread.php?t=46980&p=505500&viewfull=1#post505500
              But upload does not work.
              Apparently I still have to wait until upload does not work.
              It's All Over Now
                It looks like it worked. Well, at least I can see the attached image in post #5 and view it full size.
                  I still can not upload any files from the computer (.zip .pdf)
                  It's worth a wait that the administrator fixes the problem with upload.
                  Question
                  I currently using 86.39 MB to store 175 uploaded attachments.
                  Should I delete an old attachment to free space?
                  It's All Over Now
                    Question
                    I'm seeing the same issue with .tiff too.
                      Don't delete anything; I'll get this fixed.
                      -tb
                      "If you're the only person I irritate with my choice of words today I'll be surprised" Chuck H.
                        And further Problems with uploading attachments
                        It's All Over Now
                          Tboy,
                          I tried to add a jpg file from my computer and it does not work. There was a message that the connection is not secure (http instead of https). Maybe this will help you to solve the problem.
                          Mark
                            Thanks, that's interesting. I'm assuming that warning came from your browser; which one are you using, and when did it occur during the attempted upload process?
                            -tb
                              Testing! 1, 2,...
                              EDIT: Nothing. I typically use Chrome. I just tried uploading a new image logged in with Explorer and got the same results. Didn't check my security circumstances yet.
