Page 5 of 5 FirstFirst 12345
Results 141 to 142 of 142
Thread: Simms Watt 100w Head
  1. #141
    Sep 2016
    66
    Received: 17/0
    Given: 10/0
    4
    Quote Originally Posted by HTH View Post
    I put a choke in one of mine and I’d recommend anyone doing this - I just prefer the feel.
    HTH what do you mean by "I just prefer the feel", do you mean it changes the sound somehow?
    I have these options:
    https://en.uraltone.com/electronic-c...-marshall.html
    Auch! I found 3 cold solders that were apparently causing all the clicks and noises.
    I fixed those and the amp now runs smoothly \O/
    I'm very close now with this beast, I'm planning to check the BIAS again to get a good level.
    Thanks guys!
    4 Not allowed! Not allowed!
  2. #142
    Sep 2016
    66
    Received: 17/0
    Given: 10/0
    4
    A few hours ago I decided to jumper (?) the channels. So guitar to Normal channel 1, and then cable from Normal channel 2 to Brilliant channel 2. And it worked just fine, both channels on. I put a reverb pedal in the short cable and it sounded really nice. I played for 20 minutes and switched off with no problems.
    Now I turned on the amp and the small pilot light bulb blinked a couple of times and no power on. I'm about to open it again...
    But does this ring any bells? Would this channel jumpering be the cause?
    Fuses are ok.
    When I try measure between ground and the terminal of the mains switch I don't get any reading.
    UPDATE
    Apparently the problem was a jumper that is located in the main transformer. It wasn't making good contact. After cleaning it the contact is ok and the mains seem to work.
    The amp is now playing with me, had to take the chassis two times, first time only to discover that the problem was the power cable, now this.
    By the way, the jumper is now at 200, there is another position for 240. Europe is 220, does it make any difference having it a 200 or 240?
    2 Not allowed! Not allowed!
  1. simms watt PA150 schematic wanted
    By blindboybenton in forum Schematic Requests
    Last Post: 03-25-2018, 11:57 AM
  2. simms watt PA150 bias issue
    By blindboybenton in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-24-2018, 03:53 PM
  3. 100w valve head cutting out
    By RionZion in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2015, 09:37 PM
  4. JCM2000 DSL 100W Head issue resolved!
    By sweatyk in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-07-2015, 10:47 PM
  5. Kustom Profile one 100w PA head help!
    By Bruce / Mission Amps in forum Music Electronics
    Last Post: 01-07-2011, 11:40 PM
Tags for this Thread
