Need schematic for a Peavey PV-20 USB Mixer
  • Need schematic for a Peavey PV-20 USB Mixer
    Output amp quit. Need service manual if available, PDF appreciated. Thanks
    Contact customer service at Peavey, and ask them for it.
      Call them.
      Don't EMail.
      Peavey Electronics/Customer service
      1 (877) 732-8391
        lhttps://elektrotanya.com/peavey_pv_series_mixer_usb_scard_sch.pdf/download.html
        https://elektrotanya.com/peavey_mixer_pv10_pv14_schematic.pdf/download.html
        Peavey PV20 Schematic maintenance manual Data
        It's All Over Now
          Got it. Thanks for the help.
          Call them.
          Don't EMail.
          1 (877) 732-8391
          Got the schematic and info on repairs.
          Thanks everybody,
          Bob
            Thanks everybody,
            Bob
            Ok you have schematic and info on repairs, be kind and share it with us.
            It's All Over Now
              PV20 USB schematic
              I hope the PDF is attached! The service info I got was verbal from Peavey tech. Concerned the fact that my problem was probably a surface mounted device. I also can suggest how to open the mixer. Remove the Allen head screws on the top panel and the back bottom edge. Also remove the 3 black screws on the bottom. lift the bottom of the case off. I don't do surface-mount repairs and it would take removal of all the top panel knobs and hardware to expose the circuits . Just have to live with the 1/4" jack output for the left channel. No XLR output.
                I hope the PDF is attached! The service info ... ...
                No PDF attached, but thanks for the information.
                vk
                It's All Over Now
                  Am from the Philippines and need schematic for PV20
                    Contact Peavey directly. They'll send it to you.
