Results 1 to 4 of 4
Thread: Peavey Classic 50/50 to Bassman conversion
    Supporting Member
    Aug 2017
    Portland, OR
    810
    Received: 290/1
    Given: 119/2
    3
    In the thinking stages on this. I have a Peavey Classic 50/50 stereo tube power amp that had multiple PCB arcing issues on channel B, and I have given up on fixing it to original function. Thinking about converting it to something more interesting. Thinking about either a Bassman 50 or Ampeg B15N. Bassman has an advantage of having some cheap pre-made/pre-populated eyelet boards available. I think either amp I would have similar questions on convertibility.
    Most importantly I guess would be PT and OT specs. The 50/50 has 8 EL84s (four per channel) and plate voltage is about 450V. It seems to me like I should be able to run a couple of 6L6 tubes off this, but need to come up with the correct bias voltage from somewhere. There are two 12AX7 and two 12AT7s for the buffering and PI stages, so that seems like there should be enough current for preamp plates. Heater current should be enough considering 8x EL84s and 4x 12A_7 tubes. Is this reasonable?
    For the OT, is a quad of EL84's much different than a pair of 6L6 from an impedance standpoint? I've read 8k per tube for EL84 and 4K for 6L6. Is there a reason I couldn't use a pair of 6L6 with one of the existing OTs?
    Haven't really thought about tube rectification vs. SS. Mostly this came about because I am having a lot of fun playing bass through my Peavey 60/60 with just a tube mic preamp in front of it, and think it would be cool to have a "real" bass tube amp (I know the Bassman is known more for guitar).
    Thanks for any thoughts,
    Greg
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,158
    Received: 41/1
    Given: 42/0
    13
    Do Peavey use DC heaters in this circuit for the preamp ?
    http://www.prowessamplifiers.com/sch..._classic50.pdf
    Supporting Member
    Aug 2017
    Portland, OR
    810
    Received: 290/1
    Given: 119/2
    3
    Apologies, forgot to include link to the 50/50 schematic (related to the Classic 50 but perhaps not identical). Heater voltage is AC according to schematic. https://www.thetubestore.com/lib/the...-Schematic.pdf
    Oh, and I would not try to mount the tubes horizontally like the EL84s are, I would put them vertically up through the top cover or something.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,750
    Received: 2,162/7
    55
    The Classic 50/50 doesn't much resemble the Classic 50 at all. The Classic 50/50 doesn't have a preamp, it is just a power amp. The 50/50 also has a driver stage for the power tubes that the Classic 50 lacks.
    Forget tube rectifiers, there is no 5v supply for their heaters, and where would you put them?
  1. Dukane 1u460 PA to Bassman conversion
    By sydthegnome in forum Conversion Projects
    Last Post: 12-05-2015, 02:03 AM
  2. Peavey Classic 30 Tweed Bassman Mod Help
    By Erocku in forum Mods & Tweaks
    Last Post: 06-12-2012, 12:55 AM
  3. Fender Bassman 10 Bias adjust conversion
    By Bassisst90 in forum Tubes (Valves)
    Last Post: 05-17-2012, 08:26 PM
  4. Classic 50 2X12 Conversion Questions
    By Wittgenstein in forum Conversion Projects
    Last Post: 05-02-2011, 06:30 PM
  5. Peavey Classic 30 Bassman Mod RF noise
    By tubeswell in forum Debugging Your Build
    Last Post: 05-09-2007, 01:03 PM
