Marshall CODE
  • Marshall CODE
    Hi.
    Anybody have, or know where I can obtain, schematics for the Marshall CODE series of amps. i.e. CODE25/CODE50/CODE100/CODE100H???
    Even a simple block diagram will do i.e. I'm not so much interested in details of individual components but rather where/how the PRE AMP output is connected to the POWER AMP input.
    Regards,
    Dale.
    Originally posted by dpaterson View Post
    Hi.
    Regards,
    Dale.
    Marshall code100h head
    PRE AMP output is connected with POWER AMP input via FXloop Send (PRE AMP out) / FXloop Return (POWER AMP in) jacks on the rear side of the amplifier.
    By inserting the cable into the FXloop Send, the connection with the POWER AMP in amplifier is automatically disconnected.
    FXloop Send / Return are mainly used to connect external effects or processors.
    http://musiciansroadhouse.com/viewforum.php?f=92
    Marshall CODE
    https://my.marshall.com/support/tutorials
    Tutorials CODE
    https://www.vguitarforums.com/smf/index.php?topic=18807.0
    Marshall CODE - DSP modeling Amps
    It's All Over Now
      Hello.
      Thanks very very much for responding to my post. Really very much appreciated.
      I fear I should maybe have given more detail here (as I did on this thread: https://music-electronics-forum.com/...ad.php?t=47472).
      In short it's an effects loop that I'm wanting to try and add to a CODE25 and a CODE50 hence my looking for schematics (and if I cannot find schematics then any ideas as to where I can splice into the circuit just to add some send and return jacks to see if it will work).
      Thanks again.
      Regards,
      Dale.
