PRAT - British slang: A stupid or foolish person
About amp "immediacy"
This topic is closed.
Originally posted by Chuck H View PostPerhaps someone could post an example of a tube circuit, complete with power supply, that exploits their fast rise time potential.?.
Another anecdote about ear satisfaction - Back when DAT recorders first hit the market in the USA, I was doing some work for a local college's music department. The head of the dep't bought herself a portable Panasonic DAT but was immensely dissatisfied with recordings she got using built-in mic preamps. A consultation with the manufacturer revealed the mic pre's were designed by one of their metering specialists, and had slew rate out the wazoo. So... supposedly it was state of the art, right? Except it sounded like dreck. Hmmm..... Soon as it was available our music professor bought herself the second generation Panasonic portable DAT and was immediately much more satisfied. This time Panasonic used a mic pre design from their mic pre specialist, and stopped honking about stratospheric slew rate. A win for the ears!
From the late 60's on for a couple three decades there was a movement among studio gear manufacturers to "get the iron out of the signal path." Transformers = poison was the line of thinking. Well they might have been successful in improving their gear so that it could pass clean square waves up to a gazillion hertz, and that's fine for the meter readers. But engineers, producers and musicians kept hauling old fashioned gear into the studios. Transformer coupled, tube populated EQ's, compressors, limiters, preamps etc. Some techs made a fortune ripping apart early transistor Neve consoles - that couldn't pass a square wave to save their life - selling the preamps & eq strips all handily rack mounted - at nosebleed prices. Why? Because they sounded good! Over the last 25-30 years there has been a resurgence of "old school" studio gear being manufactured fresh, copies of classic studio gear, sometimes with extra bells & whistles but often transformer coupled and nobody in the production end of the biz gives a crap about slew or PRAT. Not that any of it guarantees good sounding music on the market... an awful lot is rubbish, but some of it is quite good. It's all how the engineers & producers use the gear, and what the execs at the record companies decide is fit to send out the door as finished product. But that's been the case since the beginning of time.This isn't the future I signed up for.
@Leo_Gnardo aka Conflator #2
No one is suggesting slew rate is the only parameter leading to good sound. The focus here was for one specific attribute and its relation to one specific outcome.
Originally posted by Chuck HAny difference to be made in the slew rate of a tube circuit to make it faster than a transistor is indeed mitigated by coupling requirements.
Originally posted by Chuck HFurther, I don't think I've ever seen a voltage amplifier that instigates significant grid current.?.
It is so sweet watching how you smooth over and apologize for each others rubbish after it's exposed. It reminds me of the males in the whale pod who fail to mate the female in the chase. So pathetic and so obstructive to the pursuit of truth.Last edited by yldouright; 10-07-2018, 02:46 PM.
I suspect that amp slew rate is a complete red herring, surely most any reasonable guitar amp will be order(s) of magnitude faster than that of the speakers used? eg https://celestion.com/product/18/Classic_Lead/
@Dave H are you able to derive a slew rate from the freq response plot?
My experience is that AB1 amps which have a lot of sag, squish and bias shift may seem to have a softer attack, which may perhaps be described as less 'immediate'.
Hence stiff HT nodes and fixed bias, along with suitable mitigation for bias shift / blocking distortion, may be a good starting point for an 'immediate' tube amp.Last edited by pdf64; 10-07-2018, 02:59 PM. Reason: Add Aiken links for sag, squish and bias shift / blocking distortion definitionsMy band:- http://www.youtube.com/user/RedwingBand
[/QUOTE=yldouright;509683] Tubes have ~1,000x faster rise times than transistors which gives them greater potential for higher slew rate circuits. [/QUOTE]
Of course that is not true. I do not know what kind of misunderstanding leads to that statement, but until you figure out why that is wrong, there is not much point in criticizing what others say.
Originally posted by pdf64 View PostI suspect that amp slew rate is a complete red herring, surely most any reasonable guitar amp will be order(s) of magnitude faster than that of the speakers used?.
One thing that I never ran across was using electrostatics for guitar amps. There were a couple Fender amps that had Yamaha speakers with super light polystyrene plastic cones, driven by the usual magnet/voice coil arrangement. Another idea that came and went fast, can't imagine why...This isn't the future I signed up for.
@Mike Sulzer
Ceteris Paribus and assuming the impedance, phase angle and damping factor issues of the drivers are sorted out, my statement stands. I've read your posts and know you're a smart guy Mike, why align yourself with these dullards on this? Yes, nowadays chips operate in the GHz range which makes the 1,000x number invalid when citing those but common audio amps don't typically use them.Last edited by yldouright; 10-07-2018, 03:19 PM.
Hey guys. Did I say jackass earlier? Sorry. I meant jackoff.
Do we usually discuss grid current as constant with respect to it's roll in amplification? I guess I was confused.
And indeed, why do the VAST MAJORITY of tube amps employ such ignorant design that ignores the 1000x greater slew rate potential that tubes offer? I'm afraid my ignorance prevents being able to understand.
Potential is an oft misused concept. It should mean "What is achievable". Unfortunately it's commonly employed to exploit a single attribute that can never be idealized. You could fly a passenger plane with a rubber band were it not for pesky things like air resistance and gravity. So using a jackoff's definition for potential a rubber band can power a plane. Why those lazy, uneducated engineers still have us using jet and internal combustion engines must be a conspiracy propagated by big oil... Or aliens."Take two placebos, works twice as well." Enzo
Yes, it may be possible that a tube's output electrode can exhibit a fast slew rate under certain conditions (dunno ), but for a tube audio power amp to actually drive a real world speaker load anywhere near 1kV/us seems fanciful.
Please help us out here, are there any commercially available examples of such an amp?My band:- http://www.youtube.com/user/RedwingBand
Originally posted by pdf64Yes, it may be possible that a tube's output electrode can exhibit a fast slew rate under certain conditions (dunno ), but for a tube audio power amp to actually drive a real world speaker load anywhere near 1kV/us seems fanciful.
Originally posted by pdf64 View Post@Dave H are you able to derive a slew rate from the freq response plot?
I think you'd need more than the small signal frequency response. If I knew the full power bandwidth, output power and load resistance I could derive the the maximum rate of change in Volts per uSec required to follow a full power sinewave at the upper -3dB point. Would that be close to the slew rate? I just don't know.
Edit: Has The Trinity recruited a 4th member?Last edited by Dave H; 10-07-2018, 04:34 PM.
Originally posted by yldouright View PostPlease be more specific. I'm assuming you aren't challenging the theoretical concepts of circuit time delays and as of yet unmeasurable signal wave smearing. Do you want scientificly quantified corroboration of PRaT or proof of its audible repeatability?
If signal-smearing is unmeasurable how do we know anything about it? Perhaps we just listen to the sound and say ‘it sounds like the signal is being smeared’.
I do not doubt that amps and speakers sound different and some of the differences are quite subtle and difficult to measure. So we resort to terms such as ‘immediate’, ‘smeared’ etc. to try to capture the subjective differences. I am genuinely interested in any scientific work on such things.
Originally posted by Malcolm IrvingIf signal-smearing is unmeasurable how do we know anything about it? Perhaps we just listen to the sound and say ‘it sounds like the signal is being smeared’.
Originally posted by Malcolm IrvingSo we resort to terms such as ‘immediate’, ‘smeared’ etc. to try to capture the subjective differences.
Originally posted by netfences View PostIn this thread, I only wanted to learn about amp immediacy and how to achieve it. As was correctly pointed out, my goal is to build an amp that is pedal friendly, uber clean and fast/present. The players in here seem to know what I mean if others don't.
Another quick observation from years of tweaking & listening, a pair of output tubes will give you better clarity than a quad - or more. Of course design with whichever output tubes are suited to the power level you're seeking, from 6AQ5's for 5W or so, up to KT88 for 60W.
Finally, power supply levels, and another subjective observation. Higher operating voltages tend to yield a brighter, snappier, more forward sound both in preamp and power amp. So keep those preamp plates around 200V, should be fine. Of course there will be naysayers, we have to expect that. But you can experiment with your amp and find out if it isn't so.
Take a look at that Traynor YGM-3 schematic, see how it compares to a Fender Deluxe Reverb. I'm sure you can adapt those circuits to your needs.
Good luck, & don't worry about slew rate or PRAT. Keep it simple, and I'll bet you will be well satisfied.Last edited by Leo_Gnardo; 10-07-2018, 08:33 PM.This isn't the future I signed up for.
