Originally posted by Dave H
View Post
About amp "immediacy"
This topic is closed.
Originally posted by uneumann View PostOK - so now you claim that some sort of quantum electronics influences the audio amp circuit in my Fender Bassman ... this is really getting far out there and becoming a laughable discussion. We crossed a line here and I suspect there is no return. Pls refer us to a credible source about this erratic momentum and 35 mph phenomena. Until you can do that, I'm just left with no alternative but to treat this as "fake" theory that you're making up.“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
-Alan K. Simpson, U.S. Senator, Wyoming, 1979-97
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
https://sites.google.com/site/stringsandfrets/
It's not about what IS. It's about confounding, diverting, chaos and discord At least a couple of posters on this thread absolutely love that $h!t."Take two placebos, works twice as well." Enzo
Originally posted by yldouright View PostI'm pretty sure I'm going to get some howls for the following blasphemy but here goes:
If the signal was truly light speed,
[...] you would see an instantaneous settling of the voltage
[...] We have been taught (conditioned) to believe
[...] More fuel for the fire?
[...] at 35mph!
[...] Is it possible that signals through a conduit are not really traveling at near light speed?
[...] current is limited to 35mph through a wire.
[...] Put another way, voltage is NOT a signal.
[...] part of the electrical science
[...] whole body of physics has to deal with
[...] high voltage fields and frequencies and how they relate to dimensional phasing. I hinted at some of these in a prior post when I referred to the relative nature of mass and speed.
It's either a closet True Believer with an axe to grind, a troll with a fascination for chaos, or a controversy bot, perhaps human assisted. They're not amenable to reason or education.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Measure an operating amp circuit in live time that would normally require feedback, without the feedback. Have a switch that introduces feedback to the circuit and watch the meters. As expected, the voltage readings are erratic without feedback. Now switch in the feedback. If the signal was truly light speed, you would see an instantaneous settling of the voltage but it takes a second or so depending on the signal path. We have been taught (conditioned) to believe its the meter taking the time but even analog meters exhibit the same behavior. More fuel for the fire? The time is takes to settle the voltage is repeatable and matches the estimated time it would take at 35mph! This is just one of the many examples we witness in real life that we dismiss without further thought about it. Is it possible that signals through a conduit are not really traveling at near light speed? I'm going to introduce one more blasphemy, voltage potential is commuted at nearly light speed to all points connected to the source but current is limited to 35mph through a wire. Put another way, voltage is NOT a signal. This is part of the electrical science that some applied physics is experimenting with. That whole body of physics has to deal with high voltage fields and frequencies and how they relate to dimensional phasing. I hinted at some of these in a prior post when I referred to the relative nature of mass and speed.
Op amp circuit without feedback? It is kind off hard to keep the op ap out of saturation because of the high gain.
Did you know that you can put a step function into a line then measure how long it takes to propagate to the end? Or you can put in an rf sine wave and measure standing waves along the line to get the speed. Guess what? It is not 35 mph.
One way Tektronix used to generate pulses with sub nanosecond fall times was to charge up a length of coax with 100V or so, then discharge the coax into a 50 Ohm load. A mercury wetted relay connected the coax to the load. The width of the pulse was determined by the length of the coax, a little less than 1 nanosecond per foot. The relay determined the rep rate, about 50Hz. The box with the relay was lunchbox size and the coax was in a suitcase sized box on the floor. They used really fat coax.
There is a formula used to estimate 3dB bandwidth from rise time (10%-90%).
Bandwidth = .35 / (risetime)
Tr of 1 nS ~ 350MHz
A 50W @ 4 Ohm amp puts out about 40V pk to pk. At 10V/uS that implies about 87KHz Bw.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Dang, R. G. ... I'm seriously wanting to change my signature now...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by R.G. View PostOK, that burst got me up to speed. Guys, save your ammunition. I'm not sure what this is, but the burst of pseudoscientific agit-prop is pretty definitive.
It's either a closet True Believer with an axe to grind, a troll with a fascination for chaos, or a controversy bot, perhaps human assisted. They're not amenable to reason or education."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Mike SulzerOp amp circuit without feedback?
To all the other members who found their sensibilities offended by the introduction of this new pseudoscience, I refer you to this post to explain your reactions. I will also remind you that the same term was directed at Albert Einstein when his miracle year papers were circulated to the academic establishment.Last edited by yldouright; 10-09-2018, 05:45 AM.
Huh. I also see he listed three options. So maybe we have one of each...
Jusrin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Mike Sulzer View PostDid you know that you can put a step function into a line then measure how long it takes to propagate to the end? Or you can put in an rf sine wave and measure standing waves along the line to get the speed. Guess what? It is not 35 mph.
Op amps are comparators without feedback but the voltages are perfectly stable if you disconnect the feedback on a Bassman or similar amp.
But again, that confuses electrons and current. Your signal delay is nanoseconds, but the electrons in the circuit are not moving from one end to another.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostBut again, that confuses electrons and current. Your signal delay is nanoseconds, but the electrons in the circuit are not moving from one end to another.
@Yldouright what do you think happens to the electrons if it's AC across the wire not DC?Last edited by Dave H; 10-09-2018, 01:52 PM.
