Fuzzface switch issue
  • Fuzzface switch issue
    Hi, I have built a Fuzzface based loosely on the Fulltone 69 pedal, with some variations. It works quite well, I like it, except that when I switch from bypass to Fuzz there is a momentary silence ...1/2 sec. ..... then it kicks in. Going back to clean or bypass to the amp its fime , no glitch. I am including the schematic in the hope I can get a resolution through the forum.
    I am trying to upload the schematic but the attatchment function does not seem to work??
    Is this the schematic?
    Fulltone 69 Fuzz Pedal.pdf
    That 1/2 second delay sounds suspiciously like a capacitor charging up.
      Maybe switching the power to the circuit off when in bypass mode?
        Here is the schematic, I hope, if the attachment works. Cannot upload my image ??
          Fuzzface PNP Schematic
          Here's the schematic that angelodp was trying to upload.
          He emailed it to me.
          GL,
          T
            The first thing that I would try is to clean the switch.
            There are bits of grease inside the switch that may be slowing down the movement of the internal mechanism.
              this suggestion did the trick., I will post the new schematic. Thanks All.
              Ange ...
              For the switch wiring, (A) and (B) need swapping and the LED needs flipping.
