Not sure if I'm missing something or maybe it has a name that I am not aware of, but I can't find the schematic for this amp on the web. Does it exist? It's quite a difficult amp to trace due to the layout.
Ampeg 720-SN schematic needed
Well a quick search turned up the model name Jupiter II 720SN. Still no schematic info to be found but is this the same amp in this lisiting?
https://reverb.com/item/4041215-ampe...om-flair-tolexWhen the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostWell a quick search turned up the model name Jupiter II 720SN. Still no schematic info to be found but is this the same amp in this lisiting?
There's no schematic in the back panel unfortunately.
Pretty big bummer as it is a beautifully done amp, but I don't know if I have the time/patience to trace through it.
The main issue appears to be in the preamp.
