First Act amp repair
This topic is closed.
  • #16
    It most certainly is a Power On/Off control ..... what else could it be?
    I dunno. In post #13, jomama says the amp has "a separate power on switch". That's where the confusion lies.
    DON'T FEED THE TROLLS!
    • #17
      Ah yes. That is confusing.
      The power switch is either separate, or the on/off volume switch. It can't be both.
      Pictures of the front and rear panels would be a big help.
      • #18
        Originally posted by jomama View Post
        I did admit I was new at this stuff but I'm a pretty fast learner. This amp has low voltage caps and a separate power on switch. I'm only replacing a pot on a disconnected circuit board so can you be a little more specific about where the danger is?
        it spins past the On/Off click point
        Ok, then,
        * how do you turn that amplifier on?
        * What happens when the volume control clicks?
        Please answer those two questions.
        Make those three:
        * what is connected to the pot switch contacts?
        Show a picture.
        I am also intrigued by:
        Does a separate power switch on the amp free me from ..... ?
        notice the conditional/interrogative tense which strongly implies *today* there is not such a switch present.
        And:
        4 posts, alternatively opposing each other.
        • #19
          Make those three:
          Hell, let's make it four:
          Does the amp have a 3-prong plug power cord, or does it run off an AC/DC adaptor (AKA wall wart) and/or batteries?
          -rb
          • #20
            I have seen some small tube amps with trem, and the trem pot has a click switch to turn trem off. There would be a separate power switch. I can see a novice calling the trem with switch a "volume control".
            • #21
              Originally posted by rjb
              The safety concern was that if you have a bad AC power switch (which we assumed was built into the volume pot) you might get arcin' and sparkin' and udder bad tings when you plug the amp into a wall socket.
              Let's clear some stuff up:
              1. There is an on/off mains switch on the back of the amp.
              2. There is a three pronged, IEC grounded plug in addition to that switch.
              3. There was an on/off, B50K linear taper volume pot on the front which failed and I removed.
              4. I ordered this pot value without an on/off feature and will be installing it today unless advised otherwise.
              I hope I provided enough information now to eliminate any confusion. Thanks again to all helping.
              • #22
                There's one last thing to clear up: The volume pot w/switch has three terminals for the pot and at least two for the switch. What, if anything, were those switch terminals connected to?
                -tb
                "If you're the only person I irritate with my choice of words today I'll be surprised" Chuck H.
                • #23
                  We're gettin' there. I can feel it.
                  • #24
                    Both the volume pot that was removed and the pots I ordered are three leg, single output. I have a bigger problem now, the pot leg spacing on the replacements ordered are too small (not wide enough)
                    Does anyone have a stash of cheap linear 50K pots with the right lead spacing to swap?
                    • #25
                      We *definitely* need pictures here, since we are on post#24 and still do not know what kind of pot you are talking about.
                      * 3 leg? ... check .
                      * "single output" ? ... what does that mean???
                      * you talked about ON-OFF and clicking. Standard 3 leg pots do not "click" nor turn anything ON-OFF
                      * "the right lead spacing" .... which would be? ....
                      * "the pots I ordered" .... I have no clue about what you ordered.
                      We need pictures showing old and new pots and pcb where it sits.
                      Also measure lead spacing on old and new.
                      And pot case diameter(s).
                      • #26
                        Oh, that's nothing. Another thread is on post #262 and we still do not know what "immediacy" means.
                        -rb
                        • #27
                          Well, "immediacy" can not be photographed, measured with a ruler or ordered at Mouser , while a pot can
                          Cīmon jomama, ease our anxiety with a couple pictures
                          • #28
                            I got a huge bag of old 50k pots. Right lead spacing??? Follow Juan Fahey's recommendation and take some pictures/measurements.
                            • #29
                              I'm sorry for the late response. I went out and got a replacement at a pawn shop so repair became low priority. Pictures are coming. It's always good to have a spare
                              • #30
                                So, what did you get as a replacement?
