Page 2 of 2 FirstFirst 12
Results 36 to 37 of 37
Thread: Marshall Valvestate 8080 has only 12V + and - on 15 volt rails and it has a loud hum
  1. #36
    Senior Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,058
    Thumbs Up/Down
    Received: 236/1
    Given: 566/1
    Quote Originally Posted by rpape2601 View Post
    I'll remember to use a colon instead of a dash when posting voltages. On IC8 pin 4 has negative 14.4, same as the power supply.
    Looking at the schematic I posted in the earlier thread this afternoon, see what happens if you lift up the IC end of R81, and connect that end of the resistor to gnd with a clip lead. Does the output go to 0VDC, or remain shifted to 4.7V or so? I'm still suspicious of the collector and emitter readings of TR6, as they don't make sense....and with 34V on TR6 Collector/TR7 base, it doesn't make sense with TR7, since I'm seeing around 32mA flowing thru TR7/TR9/TR4, which does make sense.
    It may be that IC 8 is bad, but, it may be trying to correct the overall loop around the amp due to TR6 being bad. Lifting R81 out does open the DC loop, though it's companion cap C48 is still closing the loop in it's frequency range.
    0 Not allowed! Not allowed!
  2. #37
    Join Date
    Jul 2009
    Location
    Cambridge Ontario, Canada
    Posts
    22
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'll recheck the voltages tonight. It was late when I checked them so I may have messed up on one or 2.
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Replies: 2
    Last Post: 11-03-2018, 03:02 AM
  2. Marshall valvestate 8080 repaired?
    By zoblitz in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-01-2015, 07:20 PM
  3. 117 volt transformer for a Marshall Valvestate VS100R
    By Sethkomar01 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2013, 04:55 AM
  4. Marshall Valvestate 80V (8080) problem
    By jp3zone in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-23-2011, 07:52 AM
  5. messing with my marshall valvestate 8080
    By jonfoote in forum Mods & Tweaks
    Last Post: 04-21-2009, 04:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
