How can be determined/estimated in a very simple way the ripple current performance for a filter capacitor, please ? I have to replace screen grids filter caps in series battery into a Sound City PA 100 and I just have two small FT rated at 0.2 A ripple current.This is ridiculous small relative to originals (big cans rated at half an Amp).Can I use it safe, please? Thanks
Capacitors ripple current question
Last edited by catalin gramada; 11-02-2018, 12:27 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
Originally posted by catalin gramada View PostHow can be determined/estimated in a very simple way the ripple current performance for a filter capacitor, please ? I have to replace screen grids filter caps in series battery into a Sound City PA 100 and I just have two small FT rated at 0.2 A ripple current.This is ridiculous small relative to originals.Can I use it safe, please? Thanks
What does "small" mean?
What does "originals" mean?
Canīt find those units either in my Capacitance meter nor in any equations
I can only find "microFarads" , "current", "voltage", etc.
And searching datasheets stupid Google asks for "Brand" and "model/type".
Computers are dumb.
Please show the circuit they are intended to work in, with voltage values.Juan Manuel Fahey
We really only need to compare the voltage rating and uF value of the original cap to the new ones you want to use."Take two placebos, works twice as well." Enzo
Ripple Current Characteristics in Aluminum Electrolytic Capacitors
Originally posted by catalin gramada View PostHow can be determined/estimated in a very simple way the ripple current performance for a filter capacitor, please ? I have to replace screen grids filter caps in series battery into a Sound City PA 100 and I just have two small FT rated at 0.2 A ripple current.This is ridiculous small relative to originals (big cans rated at half an Amp).Can I use it safe, please? Thanks
Nichicon Ripple Current in Electrolytic Caps.pdfLogic is an organized way of going wrong with confidence
Originally posted by nevetslab View PostI have extracted the three pages pertaining to how ripple current is derived from a technical paper from Nichicon.
[ATTACH]50975[/ATTACH]"Take two placebos, works twice as well." Enzo
At iddling should be a simple task. Have no idea how to do the measurement with a multimeter into dynamic conditions when think dramatically changing load currents generate also pulsating currents into decoupling caps as ripple..."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I believe that the reality is that normally available standard commercial quality electrolytic capacitors will be OK with respect to ripple current capabilities in the typical musical instrument power supply applications. My understanding is that ripple current becomes an issue when designing high efficiency switching supplies and conventional supplies that run at high ripple values due to high current draw. In the case of high current draw the circuit being fed may be OK with the high ripple. In musical instrument amplifier circuits the first filter stage ripple is usually less than 4% and then much much lower for the preamp stages. Therefore, catalin gramada, I do not believe that you do not need to worry about the ripple current specifications of the caps you want for your Sound City PA 100.Keep learning. Never give up.
Soundcity_100b.pdf
Originally posted by Chuck H View PostIndeed! I've never been more intimidated. How much easier to choose a cap of appropriate ratings for the circuit with a decent impedance spec and then measure the ripple current.?.
I too have never stopped to figure it all out, and leave it to the companies that do. Makes my head swim too, seeing all of what goes in to produce a generality ripple current rating chart that some data sheets carry, while other's don't. As our OP observed, the original filter cap in a vintage amp was very impressively large, then you're looking at some far smaller parts put in as replacements....what's going on here? Advancements in capacitor foil technology over the years for certain, and other refinements in packaging that achieve comparable internal temp rise from the applied ripple current have made our larger parts of old a whole lot smaller.
If size and cost are not a huge factor, I'll always select a larger part that has better DF, lower ESR, higher temp rating (105 deg C vs 85 deg C) & higher ripple current rating, just so I can be assured I've equaled or exceeded the quality of what I've replaced.Logic is an organized way of going wrong with confidence
Not reading the Nichicon paper which must certainly be very accurate and full of Math, simple thinking tells me that peak ripple current through a reservoir cap is what they have to supply under dynamic conditions, beyond idle current supplied through screen resistors.
So if, say, screens take 10mA at idle and 50mA peak when fully overdriven, then delta I , the instantaneous current variation is 40mA, and that is the ripple current.
Please repeat this with actual current values, and you donīt need any schematic for that, just read tube datasheets and multiply by how many tubes you have.
Without looking (hint, do your homework ) , I guess even 0.2A must be ample.
Doubly so if those "small" FT go in parallel.
By the way, you didnīt post model and ratings yet
You expect us to guess without data?
How many uF is "small"?Juan Manuel Fahey
Originally posted by Dave H View Postand the screen supply cap (IC2) as 100mA
[ATTACH=CONFIG]50976[/ATTACH]
That said, I think C1 ripple current value must be right, since you load it with what 2 power tubes take (the 4 of them never work at the same time) but C2 ripple current must be quite lower, I doubt screen voltage sinks down to 0V or Ground at any time.
So voltage across R2 is way less than 400 something Volts so reducing current demand accordingly.
IF those 1k resistors ever saw 400V across them they would dissipate 80W each (160W at 50% duty cycle) which is obviously not the case.Juan Manuel Fahey
Originally posted by catalin gramada View PostAt iddling should be a simple task. Have no idea how to do the measurement with a multimeter into dynamic conditions when think dramatically changing load currents generate also pulsating currents into decoupling caps as ripple...
Regarding guitar amps, it seems completely sufficient to make sure that the cap's case doesn't get hotter than its specified max. temperature at prolonged full power operation and max. ambient temperature, as the case temperature includes ripple heating anyway. If you really care.
Bigger caps have a larger radiating surface and will show less ripple heating. Also lower ESR types produce less ripple heating.- Own Opinions Only -
I took the PSUD simulation a little further to look at the steady state ripple current. I read J M Fahey's comments regarding the definition of ripple current. His takeaway, I think, is there is no such thing as steady state. But it's easier to use the industry definition and forge forward, even if we get the wrong answer! Joking aside, it's possible to setup PSUD to put a step function in the loads, so one could explore Jim's ideas.
Anyway, in PSUD, you can plot any of the variables over time by checking the box on the left. Here's essentially the same circuit that Dave H sim'ed. I think that 300mA to the plates is over estimated, but this gives a worst case answer. Anyone that wants to know what happens when you change that should download PSUD and try it themselves.
Note that the numbers in the table include the startup, which is horrifying.
If we change it to start reporting after a 1 second delay, then we can see what's happening after startup, which is more realistic.
Here we can see that the the ripple current through that cap is less than 60mA.
Originally posted by J M Fahey View PostI think C1 ripple current value must be right, since you load it with what 2 power tubes take (the 4 of them never work at the same time) but C2 ripple current must be quite lower, I doubt screen voltage sinks down to 0V or Ground at any time.
I just used double the data sheet values of plate and screen current for 2 x EL34 at 50W. That's (2 x 106) x 2 plate and (2 x 21) x 2 screen. R2 isn't a screen resistor. PSD2 wouldn't let me put a current sink there to represent the total screen + preamp current so I had to use a resistor.
EDIT: Well what do you know? I see Tony managed to put a current sink where I had R2. It's easy when you know how (I do now)Last edited by Dave H; 11-02-2018, 08:08 PM.
