Fuse plug with circuit breaker
Seeberg used to use those fuses with integral caps. That is one of those fuses with a breaker wired in. I haven't used it in years. I still have a bunch of the red cap fuses.
I bet you figured out the other stuff mostly.
The large jones plug with 120v and two bananas for 6vac. That is for Seeburg tube chassis amps.
The dual pot with a molex is for later SS Seeburg amps volume control.
The giant resistor with clip leads - I use that in place of the field coil in electromagnet speakers.
I forget what else I sent.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostSeeberg used to use those fuses with integral caps. That is one of those fuses with a breaker wired in. I haven't used it in years. I still have a bunch of the red cap fuses.
There was a samsom wireless kit and and the delay kit you sent
i can see the resistor coming in handy for sure.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by drewl View PostI've often wondered why amps didn't have breakers instead of fuses, probably cost.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Justin Thomas View PostSome did... I thought Traynors & some of the big Ampegs of the late 70s? I remember getting one amp with one; maybe a Music Man? I don't remember...
Justin
I know there was an 11 pin octal size plug, with internal jumpers. That is for Wurlitzer amps, it takes the place of the remote power switch that plugs into the chassis.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI know there was an 11 pin octal size plug, with internal jumpers. That is for Wurlitzer amps, it takes the place of the remote power switch that plugs into the chassis.soldering stuff that's broken, breaking stuff that works, Yeah!
"I've often wondered why amps didn't have breakers instead of fuses, probably cost."
Lab Series amps had them. And since they are a particular size and shape it makes it difficult to replace when they go bad, since they were stopped being made many moons ago.It's weird, because it WAS working fine.....
I don't recall the numbers correctly...
But I had a broken off Labs Series breaker - it is also the power switch - seems to me I found SOME. But if the original was 6A, I found like 5A and 12A. SO I installed the 5A, and tossed the 12A in the bottom. I figured, add an internal fuse and use the 12A as the switch, and the fuse for the protection... if the 5A turned out to be to small.Education is what you're left with after you have forgotten what you have learned.
Like when a solid state output section fails and the owner keeps trying to power it up.
(Sniff, sniff. What's that smell?)
No different than putting in an oversized fuse which you have to hunt down.
Like I said. A bit too convenient.
Originally posted by nosaj View PostI've got a Bassmaster where the board went conductive...
EDIT: Oh, yes, some Traynors have circuit breakers instead of fuses."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostThat makes two of us. The Traynor stuff didn't use the "wax soak" like the SF Fenders did. But I've had the waxed boards in those Fenders go conductive too. IMH(umble)E moisture absorption/adsorption for those black paper boards becoming conductive is not the only cause. I'm shooting into untested territory now, but I think the black pigment (carbon) under high heat, age and high voltage conditions can align to form semi conductive contact between eyelets.
Can't say I've seen similar in Traynors, but it isn't impossible I'm sure. Their boards aren't crammed with carbon black, they look grey or tan.Last edited by Leo_Gnardo; 11-12-2018, 02:41 AM.This isn't the future I signed up for.
