Originally posted by Helmholtz
View Post
Attenuators between a tube amp and the guitar speaker: some measurements and theory
I kind of like the "toroid" because the flux is confined and the complete magnetic path gives more H.
On the other hand I think a steel box for the load should effectively shield against radiated mag. fields interfering with the PUs even with a rod core coil.Last edited by Helmholtz; 11-15-2018, 01:49 PM.- Own Opinions Only -
Originally posted by Mike Sulzer View PostSuppose we haver a perfect device that can sample the voltage across a guitar speaker without affecting it and reproduce it exactly into any load at any power level. Connect an identical guitar speaker to the output. Would this second speaker sound just like the one one that is sampled? I think it must. Add a volume control to this device and you can scale the output while maintaining the sound as close as possible to the original given that the speaker is somewhat power sensitive as is human hearing.
Now replace the speaker that is being sampled with a silent device that has the same impedance, and therefore, the same voltage across it. Now "the device" and the speaker connected to it are a very good attenuator or booster. Off course, a good ss amp approaches this ideal device very closely. Given that electric guitar is not exactly audiophile, the ss amp might not have to be the very best. A light, inexpensive switching amp might be good enough.
Unlike many ideas, this one is double blind testable. You can can have someone else switch between the two, or not, and see what you can hear without knowing which is which ahead of time.
In more recent news Boss have just announced something similar with a lot of bells and whistled to boot:
https://www.boss.info/us/products/wa..._amp_expander/
Originally posted by Zozobra View PostThe bad cat unleashed was sort of like that iirc.
bad cat:
HERE'S HOW IT WORKS
The Unleash V2 converts the high voltage speaker output of any guitar amplifier up to 100 watts into a line level signal, sends it to our proprietary reactive load circuit that responds like a speaker and then into an ultra-transparent class D amplifier which allows any wattage amplifier to be adjusted between 1-100 watts without any change in dynamics or tone.
It looks as though they are attenuating the amp output, and then feeding that through a network that simulates a guitar speaker. IMO that misses the point completely; the idea is to load the amp properly so it responds as it would into a guitar speaker, and then attenuate, or reamplify, and then feed a guitar speaker. Perhaps it is just a very bad explanation.
Boss:
The boss might be loading the amp properly, but what it does after that is not clear to me, except there is an ss amp for reamplifying.
Originally posted by Helmholtz View PostAnd a toroidal core has minimal leakage and avoids the PU interference issue as reported by Chuck. But as the choke will have to handle several amp(ere)s, saturation may be an issue without an airgap.
I have some 1 mH (I think) coils intended for crossovers, air core. Maybe it would be easiest to make a "Chuck H" sandwich, and then experiment with adding more metal until the eddy current loss is about right.
Originally posted by Mike Sulzer View PostI have some 1 mH (I think) coils intended for crossovers, air core. Maybe it would be easiest to make a "Chuck H" sandwich, and then experiment with adding more metal until the eddy current loss is about right."Take two placebos, works twice as well." Enzo
Originally posted by Mike Sulzer View PostWhat I am thinking of here is two simple pieces:
1. A perfect voltage follower, or rather a follower with gain.
2. A silent device that has the same impedance as a speaker.
The first is what a good ss amp strives to be, The second has not yet been discussed here, but I think a passive device should do the job. Chuck H has sone posts with some pretty nice components, including a hum canceling inductor, and so I was thinking of building on that. For example, it appears that the inductor needs some eddy current losses. Could one use a short stack of really large steel washers as a poor's man toroid? I think I will try that and see how it works.Experience is something you get, just after you really needed it.
Originally posted by nickb View PostAnd that is exactly what a properly configured transimpedance amp will do for you. The forward amp is a voltage amplifier with variable gain. That puts whatever voltage that appears on the tube amp terminals across the actual speaker. You have a second reverse amplifier that senses the speaker current and voltage which loads the tube amp so that it thinks it's loaded by a real speaker.
The Boss Waza Tube Amp Expander box sounds like the sort of device everyone has been trying to achieve. Sort of takes all the fun out of the physics lab efforts, as the chase is so invigorating, as seen following your thread. Guess I'll have to make it to NAMM show this January, or stop by at the Roland Industry Office across the street to see what they know about it. We have Artist Relations offices here at our rehearsal studio complex...Fender, Zildjian, Paul Reed Smith, Roland, to name a few.Logic is an organized way of going wrong with confidence
Originally posted by Mike Sulzer View PostYes, you would need enough steel so that it would not saturate. On the other hand, the rod would have an effective permeability of under 10, and so I think you would need a lot more turns. I am not sure which weighs less: the steel shielding box or the steel toroid.
I have some 1 mH (I think) coils intended for crossovers, air core. Maybe it would be easiest to make a "Chuck H" sandwich, and then experiment with adding more metal until the eddy current loss is about right.Experience is something you get, just after you really needed it.
Originally posted by nevetslab View PostThe Boss Waza Tube Amp Expander box sounds like the sort of device everyone has been trying to achieve. Sort of takes all the fun out of the physics lab efforts, as the chase is so invigorating, as seen following your thread. Guess I'll have to make it to NAMM show this January, or stop by at the Roland Industry Office across the street to see what they know about it. We have Artist Relations offices here at our rehearsal studio complex...Fender, Zildjian, Paul Reed Smith, Roland, to name a few.
Originally posted by nickb View PostJust a suggestion. Before putting humongous effort into reproducing every nuance that you can measure might it not be a good idea to figure out which ones actually have an audible effect? I bring this up as I was particularly struck by olddawg, a regularly gigging musician on the road and in the studio, who finds a simple resistive attenuator quite satisfactory.
Sorry Mike - I promise not to divert your excellent thread again.Last edited by nickb; 11-15-2018, 08:27 PM.Experience is something you get, just after you really needed it.
