Page 4 of 5 FirstFirst 12345 LastLast
Results 106 to 140 of 147
Thread: Attenuators between a tube amp and the guitar speaker: some measurements and theory
  1. #106
    627
    Received: 41/0
    15
    I don't think reactive loads are bad per se otherwise a lot more people would have complained over the years which is not the case. Also bigger companies wouldn't have jumped on that train either. It's more like what mhuss said earlier:
    I've often wondered if the bad rep attenuators get for blowing up output stages isn't due to the fact that most people wouldn't run their guitar amps on "11" if they had to deal with the full volume. Except for maybe arenas, it is sort of self-limiting. With an attenuator, one is much more likely to run the amp way hotter then normal. And particularly with the tubes being made today...
  2. #107
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Fully dimed through an attenuator, I have seen the screens actually sag & then melt/ short out.
    Pentode screens are delicate (more so than beam tretrode screens) and heat up much faster than the plates. Screen dissipation increases strongly when the plates are driven into saturation. Screen dissipation is further increased with a more horizontal loadline, i.e. high load impedance. This is the reason why I warn against doubling speaker impedance.
    If power tubes actually die early when using a power attenuator, there are only 2 possible explanations. Either the tubes would have died just as well when using speakers at prolonged periods of tube saturation. Or the attenuator impedance does not match the speaker impedance over the whole frequency range.
    I have seen and measured the frequency responses of several "reactive" power loads/attenuators that showed way too high impedances around the resonance and above 1kHz. The reason was that they didn't provide appropriate damping for the inductors used. This could be an explanation for screen failures.
    1 Not allowed! Not allowed!
    - Own Opinions Only -
  3. #108
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    Yes, as shown in the first post in this discussion, the magnitude of the impedance of a speaker could appear to imply that it is nearly perfectly inductive at higher frequencies. But a measurement of the full impedance shows that this is an illusion because there is a large resistive component that also is also rising in magnitude with frequency. Maybe some people designing attenuators do not understand the difference.
    For the other possible explanation, I am not convinced that guitar amps are as fragile as that implies. The screen resistors are there for a reason. In a guitar amp, tube life might be nasty, brutish and short, but they do reach adulthood. My ears tell me that much of the hard rock recorded over the years used output stage distortion, often very heavy. Of course, this was encouraged by the lack of a master volume control on how many popular Fender models?
    I do not think they were replacing the tubes every couple of hours.
  4. #109
    Feb 2010
    12,641
    Received: 2,186/24
    Given: 5,507/11
    24
    I don't think anyone meant anything as extreme as tube replacement 'every couple of hours'.
    How would you be with 'significantly more often than without the attenuator'?
  5. #110
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    EDIT: I forgot to say that the restive divider used in the Russian circuit can be replaced with a transformer. This does a better job of copying a reduced voltage from the load to the speaker. What you want is a "bridging" transformer, one that is considerably higher than 8 ohms looking into it.
    That's the principle of my Marshall PB 100. I uses a speaker emulating circuit connected to a multi-tapped autotransformer for power attenuation.
  6. #111
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Could someone explain how to calculate the voltage and current distribution in the modeled circuit? I'm not sure how to specify power handling requirements where the network has reactive/storage devices and resistance/dissipation components.
    Here are some simulations of current/voltage distribution(s) for an emulation of a 8 Ohm 4x12 Marshall cab. Input voltage 37Vrms (171W apparent power), corresponding to a clipping 100W head, kind of worst case:
    1) At bass resonance (116Hz)
    SEres.pdf
    2) At 400Hz
    SE400.pdf
    3) At 5kHZ
    SE5k.pdf
    Resistor power is easily calculated from the voltage across them.
    The chosen frequencies do not necessarily represent worst case for specific components. E.g., the 12.5mH inductor current increases below the bass resonance to around 5A.
    In real guitar signals, power is distributed over a frequency band with a probability maximum at middle frequencies, so some de-rating of component loads at the frequency extremes is feasible. But distortion increases high frequency energy content.
    Current distribution will be different with different component values.
    2 Not allowed! Not allowed!
  7. #112
    Supporting Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    SEres.pdf
    2) At 400Hz
    SE400.pdf
    3) At 5kHZ
    SE5k.pdf
    That's kick-ass, man. That was super helpful to see some visual examples like that.
    Made it clearer to think of it in terms of Kirchhoff's laws.
    I will say, that at first glace I was kind of surprised that the inductance presents that much of a difference at 400Hz vs 116Hz.
  8. #113
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    What is the effect of a resistive load versus a speaker load on the amplifier waveform?
    The top panel shows the waveform with resistive load, the bottom with the speaker load. (The voltage levels are very different because the sample ports on the two loads have very different levels of attenuation.) The resistive load is 7.8 ohms; the speaker load is that described earlier.
    The amp uses EL84s, grid biased for about 70% dissipation limit. You can tell this is hard overdrive because you can see that one tube shuts off before the other turns on as a result of charging of the coupling capacitors. The asymmetry might be a result of differences in the drive, output tubes, or both; I have not looked into this.
    The frequency is 300 Hz; thus the fundamental is at the minimum point in the speaker impedance load where the impedance is real. The bass resonance is not involved in this test; the differences are a result of the damped inductor that has its major effects above 300 Hz. The effect of the speaker load is to "round" the waveform, reducing the content of high harmonics while distorting the waveform on a time scale that introduces more lower harmonics.
    3 Not allowed! Not allowed!
  9. #114
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Thanks for this impressive piece of evidence, Mike!
  10. #115
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    Thanks. One goals of this work was to look at how a speaker affects a tube amp waveform without going deaf or getting murdered.
  11. #116
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Quote Originally Posted by Mike Sulzer View Post
    Nice traces! Im wondering how the bias excursion caused in part by the capacitor coupling effects the output waveform under heavy drive vs a directly coupled drive? My amp is dc coupled EL84s, so I could adjust the bias to 70% (HT 320V) and compare waveforms once I construct the reactive load. Actually, I use a 1X12 eminence red fang i can scope. Ill just use ear protection. The resolution on my digital scope is total shit, so i may end up using the old 465 instead.
    The resolution on your images looks great though. What are you using?
  12. #117
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Two questions:
    - In an earlier post you mentioned "high" voltage spikes at the power tube plates. Did these only show at the primaries?
    - Does your amp employ global NFB?
  13. #118
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    Quote Originally Posted by SoulFetish View Post
    Thanks. With dc drive you should see less rounding since you can get higher peak current, but you do not know for sure until you try it. I have some concern for the screens of the EL84s, but with 320 volts I hope you are OK.
    For signal sampling I am using an Apogee Element 24. It feeds the scope from Electroacoustics Toolbox. When I measure impedance, I use the Element 24 and my own software.
  14. #119
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    The screens are right around 300V, and have 1k/5W screen resistors. Plus there is shared cathode resistance adding degeneration for some compression effect. Im not worried, but im putting it through abusive testing to make sure.
  15. #120
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    I'm resurrecting this thread and project because I think it's a good one, and I was hoping to find out if anyone has made any progress on building/completing/testing this and hear what kind of results they got. It's been on the back burner for me for a while, but I have some time and a little extra cash to start sourcing parts. One of the challenges has been finding the balance of cost and size efficiency to use film caps for the ≈390F capacitance.
    I found some really good deals today on 100-150F film caps, with voltage ratings from 100-500V and was going back and forth over +/- $4 (man, I must be painfully cheap.) Anyway, I was working in my shop on another project and I found a stock of 50F/250V electrocubes caps I got a while ago totally forgot about. There were like 12-15 of them in the box, so I decided to make a capacitor bank using 8 in parallel.
    Best part is I get to hold onto that $4.
    I was going to buy a pair of Jantzen 1031 0.47mH 18 AWG Air Core Inductor for Lh0 & Lh1 and wanted to double check that these are appropriate.
    I know that Mike used the secondaries of a filament transformer for the large inductor (Lb) in the prototype. But if I was sourcing out a designated filter choke for the project, can you guys offer up some suggestions to get me in the right direction? I was thinking 4-5A rating (maybe 6?). The whole unit is probably going to have to be large anyway to accommodate the caps. Go big or go home, I say.
    The last question for Mike, Helmholtz, Nickb (and others) is what kind of ideas where you thinking about for the secondary solid state drivers?
    for those who may be interested, here are some great prices on film caps for the capacitance needed:
    130F-500V
    110F-450V
    120F-250V
    100F-450V
    100F-100V
    100F-63V
  16. #121
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    In principle you could use any linear, low output impedance (power) amp. Even an integrated amplifier with tone controls. Just make sure to attenuate the dummy load signal to a level that suits the slave amp's input sensitivity using a voltage divider of total resistance between 1k and 5k. If you attenuate to line level, you may insert line level effect units between dummy load and slave amp, e.g. reverb, delay, chorus, equalizer...or even go quasi stereo with one dry and one wet signal into a dual channel amp connected to guitar speakers.
    After I have finished my Marshall PowerBrake attenuator project, I will experiment with my old and trusted Dynaco Stereo 120, which has become part of my lab equipment.
    BTW, if you make the capacitor(s) switchable you can emulate the bass response of different speaker/cabinet types. Closed cabinets raise the bass resonance frequency (e.g. vintage Marshall 4x12: fres=120Hz). This would require a cap value of 150 to 180 with a 12mH choke.
  17. #122
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Interesting idea, i had thought about the need for an cab/speaker emulator circuit for a possible direct out. But, I like the idea of having Variations in the reflected load. Too bad they didn’t make small variable auto transformers, you could probably use something like that as a variable inductor to dial in a pretty broad range of LC resonance.
  18. #123
    627
    Received: 41/0
    15
    I like to insure myself so in the reactive loads I've built so far I was using 1,2-1,3mm thick copper wire (~16AWG) air core inductors. Same for the low freq inductor. For caps my choice was two 100uF/350V motor start caps in parallel (this way they can fit into an 1U rack enclosure). All this is for a load that can handle cranked 100 Watts.
    Considering the LF inductor choices you can use a Hammond 159ZJ 10mH/5A choke or go for this one for example:
    https://www.parts-express.com/erse-s...-coil--266-946
    For those in Europe at Banzai they have the full Mundorf list of caps and inductors.
    You can also check Ebay and Aliexpress for 200uf 250-450V CD60 motor start caps (for a 8 Ohm load).
    Also I'm running 2 or 3 power resistors in parallel on a massive heatsink fan cooled (Marshall Powerbrake fan circuit) to make sure that if one them fails the amp will have some load left (although with a massive fan cooled heatsink that's very unlikely to happen).
  19. #124
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    I was also have looking at a 15AWG .47mH jantzen 1518 as well. For a few bucks more, I’ll go with those.
  20. #125
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Not sure if we mean the same with "emulate". I meant emulate the bass impedance of different speakers/cabinets. The attenuated and amplified dummy load signal needs to be connected to a guitat speaker.
    A direct out for full range reproduction would require additional filtering to emulate the frequency response of a guitar speaker.
  21. #126
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Don’t sweat it. I knew what you meant.
  22. #127
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    So, I just got the main reactive components to build this proper.
    For the main dissipation resistor(s), I have 55Ω/50W resistors I can run 10 in parallel. Or, I can buy a 1 or 2 higher power resistors at some point.
    But I'm looking for an aluminum enclosure I can use to house these components--tall enough to mount the caps and install a fan, and enough real estate to install an active speaker driver.
    Any suggestions?
  23. #128
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Some remarks:
    - A steel housing could be expected to provide better shielding of the air chokes' magnetic fields and prevent coupling with the PUs. Aluminum needs to be very thick for similar results.
    - Directly mounting air core chokes to aluminum can decrease their inductance by 20% and more. There are several influencing factors and I recommend measuring inductance.
    - Closely mounting 2 air chokes also changes inductances.
  24. #129
    Mar 2008
    872
    Received: 112/0
    Given: 242/0
    13
    Some remarks:
    Completely agree. This was a reason to mount my coils on the wood blocks otherwise coupling derive can be( see my attenuator pic below). Also the position into chassis (eg. mounting into a corner) can do a difference. The inductance should be measured with inductors mounted into chassis.
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
  25. #130
    Mar 2008
    872
    Received: 112/0
    Given: 242/0
    13
    Any suggestions?
    Take a look at Hammond dealers for case.
  26. #131
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Some remarks:
    Thanks. I hadn’t considered those factors.
    I was thinking about aluminum for the heat dissipation and weight. I suppose I could just use a steel chassis.
    Initially i was going to mount them (air coils) on two small computer fan grates(grills)
  27. #132
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Do you think it would be better to mount them with internal screening (inside the enclosure), so not to radiate into any drive circuitry I may include?
  28. #133
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    Sure, if you can find some small steel enclosures for the air coils, that will help. But keep some distance between steel surfaces and chokes as otherwise inductance will increase.
  29. #134
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    What do people use to physically mount these things?
  30. #135
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,460
    Received: 3,078/5
    Given: 3,723/0
    32
    When I built my phony speaker load for my own attenuator I used air coils and had significant feedback with single coil pickups within about nine feet of the unit at full attenuation.
    I've tried copper shielding inside an aluminum enclosure. Didn't help much (grounded or otherwise). What worked for me was to make the inductor sandwich. Two coils in series, out of phase, stacked one on the other with two thin insulating plates and a copper plate in between those. BARELY extending beyond the coils. The goal was to create a RADIATED anti phase EMF. It worked with respect to mitigating interference with the guitar or any amplifier components, but...
    I didn't test for preserved coil inductance. I could hear that there was a reduction of the original value. How the anti phase EMF works as a sort of reverse humbucker shouldn't be sensitive to the value of the inductors though. So if actual inductance testing of the assembled "inductor sandwich" was done then the values of the individual inductors necessary for the assembly to get a desired 'in circuit' inductance could be determined.
    JM2C (based on my own experience)
  31. #136
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,350/1
    Given: 1,337/2
    8
    I would think of cable ties or a nylon center bolt and plastic washers. Or epoxy potting them into suitable small enclosures. Maybe it's enough to hot-glue them to a board.
    But first I would do some tests to check if wire temperature stays uncritical at full power.
    I am not saying that metal mounting hardware can't be used but influence on inductance is hardly predictable. OTOH, variation up to say 10% shouldn't be problem as speaker inductances also vary.
    I decided for a different approach, using a single choke with a heavy steel center bolt as core. This construction took me some time to optimize, but now emulates the high frequency impedance of a speaker very well. Only drawback is that the steel core will have to dissipate up to 25% of total amp power.
  32. #137
    627
    Received: 41/0
    15
    I got my inductors from the local transformer shop. Here's some observations.
    The lamination core inductor measured ~9.5mH out of the enclosure (1.2mm black steel) and ~11mH when installed. There was no room for experiments because it was an 1U rack enclosure and I had other stuff right next to that. Using stainless steel bolts and brass or plastic standoffs for mounting didn't affect the inductance any further.
    The air core inductor would buzz at close to full power. Also at close to full power the bigger inductor made the enclosure vibrate so in the end I had to use some 15mm thick soft rubber in order to eliminate most of those vibrations but that power has to go somewhere, right?
  33. #138
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Both the nylon washers and bolts, and potting sound viable. If I decide to pot the, I have some small steel powr Transformer covers I could use.
    On the other hand, the copper temp in these coils concerns me a little. At 18AWG, these are a bit underrated compared to the other parts.
  34. #139
    Mar 2008
    872
    Received: 112/0
    Given: 242/0
    13
    For an project potting and encasing will be the last think I'll do. It is very easy to effective modify the value of a coil take off or add some turns if necessary to adjust. You can made further some additional taps for experiments.Sometimes few turns can be equivalent with a coil of same size if need to add.(the impedance of a coil raise slow at beginning of turns and very fast at the end).
    And be aware, under rating prone to saturation (just for iron cores at certain freq.) so take this in consideration aso.
  35. #140
    Jan 2016
    Massachusetts
    1,414
    Received: 543/1
    Given: 456/0
    7
    Update.. on the race to take the most time to complete an attenuator project. Not for nuthin', but I feel like I'm kicking ass in this race.
    In reality, I'm fixating on the enclosure design, and haven't been able to settle on anything yet. But while I sort that out, I found a great score for the main dissipation resistor over the weekend (I was going to use several equal parallel resistors to get the 5-6Ω I needed).
    I found a nice aluminum Dale 250W resistor on ebay for around $16 shipped.
    I think he still has one left if anyone wants to jump on it.
    https://www.ebay.com/itm/Dale RH-250 5.6Ω 1% 250W
  1. 2 Tube Guitar Amps into 1 speaker ?
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-01-2018, 02:23 AM
  2. A Theory about speaker wiring.
    By shootingstarno in forum Theory & Design
    Last Post: 02-04-2016, 05:41 PM
  3. Speaker attenuators ...
    By craig1 in forum Mods & Tweaks
    Last Post: 11-07-2009, 03:44 AM
  4. tube amp attenuators
    By Valvehead in forum Theory & Design
    Last Post: 05-05-2008, 09:17 PM
  5. Bridge and waist - guitar design theory
    By Mark Hammer in forum Guitar Tech
    Last Post: 01-30-2008, 03:29 PM
