These are on sale at Amazon for $49. Behringer VT 999. I couldn’t help myself. People have been raving about these things for years and you could scarcely buy the case for that. Unfortunately the damn thing sounds like a bad Muff to my ears. Does anyone have the REAL schematic for it? A lot of people suggest changing the tube and using a 12v instead of a 9v power supply. Seems like that could mess with the filament voltage. Maybe it’s clamped with a zener? Does 12v work better for a “starved plate” circuit like this? Might change the clipping threshold?
Behringer VT 999 Vintage Tube Monster Pedal
Originally posted by Mark Hammer View PostWhen tube amp owners desire a less intense tone, they will sometimes switch to a lower-gain preamp tube in the 12A-7 series, such as a 12AY7, 12AT7, or even 12AU7.
You can measure it to be sure, but I'll bet they're running the filaments off the 9V supply anyway, so I don't see why a 12V supply would be a problem. You may want to check to see if there's a zener at the input, though. You might have to clip it out to actually get 12V crammed in there."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Agree with The Dude about the heaters, check what they are running for stock voltage. Rather than stressing them, they may be starved to begin with, in which case you will be upgrading.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
