Results 1 to 3 of 3
Thread: 1976 Phase 90 Caps
    Aug 2006
    452
    Received: 12/0
    Given: 51/0
    14
    1976 Phase 90 Caps
    My old P-90 seems to have lost some zing..It seems to not whoosh as deep as it did 40 yrs ago Playing Pink Floyd type riffs it sounds OK,but doing Van Halen type riffs and noise it is not as strong sounding. Would replacing the electrolytic caps solve some of this.. thanks DAB
    Aug 2006
    452
    Received: 12/0
    Given: 51/0
    14
    it only has 2 tant polarized caps 4 green.05 caps, 6 741 and a few ceramic caps,and 2 blue mylar.1 and 4 t12n5952 .this might be a script logo P-90
    Apr 2010
    Burbank, CA
    1,689
    Received: 584/1
    Given: 1,372/1
    11
    Quote Originally Posted by dumbassbob View Post
    This is the week to work on MXR Phase 90's, apparently. Randall attached the following schematic to help troubleshoot a failing zener diode in his bench project. Yours pre-dates his, having 6 discrete IC's, but this looks like a circuit we can follow.
    Jazz P-Bass provided this version of the schematic:
    MXR_Phase90_1993.pdf
    This later version (1st schematic) replaced the slower/lower bandwidth 741 IC's with 3 Dual TL062 Bi-FET op amps (incorrectly labeled TL061's). TL-072's will also work there, but, as you indicated this Phase 90 has lost it's character over the years, I wouldn't expect the IC character to be at fault.
    C8 & C15 would be your two Dip Tantalum polarized caps. They're not in the signal path, but C8 is the one most likely to fail first. Not an issue at this time. The 4 green 0.05 caps are C1, C3, C6 & C9 in the phase shift network That leaves the few ceramic caps to be C2 (maybe) on the output of Q2, C5 (maybe) on the input, C4 across the bias trim pot and C7 feedback cap across IC1B. I would replace the input cap C5 and output cap C2. The green 0.05uF mylar caps in the phase shift network are probably ok, but, we could replace those as well with new 0.047uF film caps. I'm guessing the blue 0.1uF mylar caps you mentioned...one is the output cap, the other isn't shown on the upper schematic, but is in the lower one, in the feedback shunt network C2. If the ceramic caps are both the input and output caps, then definitely replace those with new film caps.
    Size is an issue with the replacement caps. I think the lead spacing on your board for the film and ceramic caps is 0.2" (5mm). You could try small footprint metallized polypropylene or metallized mylar...I've attached some data sheets to look at, available thru Mouser or Digi-Key.
    WIMA_MKP_5mmLS.pdf
    WIMA_MKS_2-5mm LS.pdf
    Vishay-BC mkp-5mm LS.pdf
  1. Phase inverter coupling caps placement.
    By wozt in forum Build Your Amp
    Last Post: 04-01-2015, 10:45 PM
  2. Fender Super Reverb 1976
    By Reimer in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2011, 03:48 PM
  3. Need roland jc120 schematics 1976-77
    By barryachi in forum Schematic Requests
    Last Post: 01-24-2010, 10:41 AM
  4. 1976 Bassman 50 help
    By Lizard King in forum Mods & Tweaks
    Last Post: 12-21-2007, 02:08 PM
  5. Replies: 20
    Last Post: 12-02-2006, 09:12 PM
